Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jan 6, 2012 at 9:55 PM
    #1121
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Its really up to you, if you think you'll be using it alot on the highways then just get the 2.5". I like my 3" cause it fits the 33's. Once i get rid of the BL i will need the full 3".
    I use my truck as a DD and do about 1300 miles a month back and forth to work. No real issues or problems besides one torn cv boot and steering wheel is off center. I plan on just getting life time warrenty axles.
  2. Jan 6, 2012 at 10:03 PM
    #1122
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    You'll be fine stuffing 33x10.5 on 2.5" lift I'm still stock and could easily stuff some 32s under there with a 3" lift I may be able to stuff some narrow 35s under it
  3. Jan 6, 2012 at 10:07 PM
    #1123
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    eh i guess ill just get the 2.5 and call it a day. all of this hassle over .5", wow i feel sort of dumb
    2nd gen,
    irrelevant,
    ban
    :D
  4. Jan 6, 2012 at 10:08 PM
    #1124
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    2nd gens have alot more room to fit 33's.
  5. Jan 6, 2012 at 10:11 PM
    #1125
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    that looks like a 2nd gen win...
  6. Jan 6, 2012 at 10:57 PM
    #1126
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    With Eibachs it is more like 1" more...but who is counting. :p
    Most rubbing on wide tires (12.5" wide) is on the frame. On narrow tires (10.5") that is less of an issue. If you go with stock wheels you will increase the chance for minimal to none for rubbing because the backspacing is not less than 4.5". If you go aftermarket wheels with 4"s or less of backspacing, you will likely see more rub on the pinch weld area.
  7. Jan 7, 2012 at 2:25 PM
    #1127
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    :cool:
  8. Jan 7, 2012 at 4:13 PM
    #1128
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    IT HAS BEGUN:headbang:
  9. Jan 7, 2012 at 4:24 PM
    #1129
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    What do you think of this material? Only $2. Im going to shape it out and see how it looks painted. Its very flexible so im not sure if ill be able to get it nice and flat.
  10. Jan 7, 2012 at 7:42 PM
    #1130
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    looks cheap chicken wire and will probably come out looking like crap:cool:
  11. Jan 8, 2012 at 11:10 AM
    #1131
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
  12. Jan 8, 2012 at 3:10 PM
    #1132
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    What happened Ben?
  13. Jan 8, 2012 at 4:14 PM
    #1133
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I think ben got lost
  14. Jan 8, 2012 at 4:18 PM
    #1134
    MTgirl
    Weesa
    Bob's secret mod lair
    Ben's back...I got a PM from him. Maybe he's grounded :notsure:
  15. Jan 8, 2012 at 4:20 PM
    #1135
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Start baking cookies i have pictures
  16. Jan 8, 2012 at 4:21 PM
    #1136
    MTgirl
    Weesa
    :rofl:
    Sorry, limited time offer...:eek:
  17. Jan 8, 2012 at 4:22 PM
    #1137
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    for now this is all you get
  18. Jan 8, 2012 at 4:24 PM
    #1138
    MTgirl
    Weesa
    the tow truck got stuck too?
  19. Jan 8, 2012 at 4:26 PM
    #1139
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    nope it did just fine! snow cleats and chains for the win
  20. Jan 8, 2012 at 4:28 PM
    #1140
    TexasTacoma37
    TexasTacoma37 Well-Known Member
