Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 7, 2012 at 9:07 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    :woot: I took the lead in the Members choice! Now i just need to hold on to it :devil:
  2. May 7, 2012 at 10:05 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    congrats Ian
  3. May 7, 2012 at 10:11 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    WOOT! good job.
    first final today! yea!
  4. May 7, 2012 at 10:38 AM
    BradyT88
    BradyT88 Well-Known Member
    FML!! I just drilled a hole through my bed liner to run the coax through. I had to come up from underneath so I got covered in the dust from the drilling. Turns out the bed liner is fiberglass and not just plastic...
    Since I am still waiting on a mount from ATO I just ziptied the antenna up. haha:D I tried it out but I didn't pick anything up... hopefully that is just cuz there is no one to pick up here in Malad.
  5. May 7, 2012 at 10:46 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    haha yea the bed is fibre glass... don't inhale.
    make a mount that's what I did way cheaper than an ATO mount.
  6. May 7, 2012 at 10:54 AM
    BradyT88
    Where'd you ground yours to? I was going to try the bolts that you used for your mount but I think there was too much paint there. I rigged up some extra speaker wire and ran it down to one of the bolts on the tow package mount.
  7. May 7, 2012 at 11:41 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I have a Zero ground coax cable. :cool:
  8. May 7, 2012 at 12:00 PM
    BradyT88
    Never heard of that. haha
  9. May 7, 2012 at 12:08 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    speaking of cables. Im going to order my CB cable and antenna tonight..but i don't know what cable to get??
    my Midland has this on the end of it
  10. May 7, 2012 at 12:29 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    :popcorn:
  11. May 7, 2012 at 12:39 PM
    MTgirl
    Weesa
    Just give him a nice smack on the ass :rolleyes:
  12. May 7, 2012 at 1:00 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Good luck! Had one this morning.
  13. May 7, 2012 at 1:05 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    finals suck thank god I don't have any :woot:
  14. May 7, 2012 at 1:27 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Listing for the runner removed on Craigs..called the guy but didnt get an answer.
  15. May 7, 2012 at 2:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  16. May 7, 2012 at 2:43 PM
    BradyT88
  17. May 7, 2012 at 4:19 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  18. May 7, 2012 at 4:37 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    hey buddeh! One final done, one to go wednesday then im donezo! complete shit semester, busy as hell up until finals, then it got really easy...how does that work?!
  19. May 7, 2012 at 4:50 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    [​IMG]tell me more!
  20. May 7, 2012 at 5:02 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    study more:cool:
