Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 7, 2012 at 5:23 PM
    BradyT88
    BradyT88 Well-Known Member
    So I had my cb on when I went into town to see if I could pick up any traffic. I think I kind of did at one point. I need to play with the squelch control some. One thing I did notice is that when I press on my brake pedal, my cb will squeal for a second or two everytime I press the pedal...
  2. May 7, 2012 at 5:29 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Did Curt hit back?
  3. May 7, 2012 at 5:34 PM
    MTgirl
    Weesa
    :laugh:
  4. May 7, 2012 at 5:41 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Channel 11 is super popular here, more so than 19 even. If you are near the hwy you should be able scan the channels under 25 and find SOMETHING. You tuned the antenna right? As far as the brake thing...I dunno. Did you tap into a light fuse or something?
  5. May 7, 2012 at 5:43 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    howdy threadagains
  6. May 7, 2012 at 5:46 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Adamantics
  7. May 7, 2012 at 5:51 PM
    BradyT88
    The cb is grounded to the same ground as the inverter uses under the console. The antenna is grounded to the frame, it's a shitty setup though, cuz it is a temporary setup.
    I just sat on channel 19 for the most part, I thought I might pick something up since I was only a mile or 2 from I-15.
  8. May 7, 2012 at 5:53 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    the inverter will cause a TON of interference... it's taking a DC current and making it an AC current. you're getting induction from the inverter.
  9. May 7, 2012 at 6:04 PM
    BradyT88
    hmm... You think it still would even with the inverter off? I guess I will have to go move my ground if I can get to it now. haha
    Oh and do the coax connections have to be completely tight? I left the right angle connector just loose enough that it can spin around.
  10. May 7, 2012 at 6:28 PM
    BradyT88
    So I should take both the positive and negative wires on the cb to the battery? The positive is connected directly to the battery.
    I went and played with the squelch button, now that i know how to use it, and I actually picked up some traffic on channel 21. I could almost understand what they were saying but not quite... Although if that traffic was coming from the freeway that is over 10 miles away. If that's the case I think I should be good to go, except for the squeal from the brake pedal...
  11. May 7, 2012 at 7:07 PM
    MTgirl
    Weesa
    :rofl: I'm checking the MT DMV now.....
  12. May 7, 2012 at 7:13 PM
    MTgirl
    Weesa
    For a sig? That would be great. There are plenty of tasteless sigs and avatars out there, this one doesn't even come close to those!
  13. May 7, 2012 at 7:16 PM
    BradyT88
    I read an article on here that said to ground the mount rather than the antenna so I just tried that and the brake squeal is mostly gone:D There is still a noise for a quarter of a second when I hit the brakes, but it's much better than the really loud squeal I had before.
    I really doubt the DMV would let you have that plate, but it would be epic. I would love to have that here in Malad during deer hunting season. We get tons and tons of Cali and Utah hunters here...
  14. May 7, 2012 at 7:19 PM
    BradyT88
    I like it:D
  15. May 7, 2012 at 7:27 PM
    BradyT88
    My coax runs out through the floor in the back seat. I have my antenna mounted at the back of the bed.
    My coax is 12 ft long and there is no coiling as it is almost the perfect length. Yeah I need to tune the antenna, but I don't have an SWR tuner and don't really want to spend the money on something I will only use once or twice...
  16. May 7, 2012 at 7:34 PM
    BradyT88
    :rofl: You must have never been to the North West US before. haha:D
  17. May 7, 2012 at 7:37 PM
    MTgirl
    Weesa
    Never ever go to Alaska in July. You want to see a mess you should see the beaches after dipnetting season. I just laugh because everyone up there is all worried about the japan tsunami debris washing up on the coast. That's probably go to amount to 1/10 of the trash people leave behind during dipnetting.
  18. May 7, 2012 at 7:38 PM
    BradyT88
    I felt the same way when I saw that haha. I have heard him called that before even and forgot.
  19. May 7, 2012 at 7:39 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    what a bunch of derps
  20. May 7, 2012 at 7:49 PM
    BradyT88
