Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 11, 2012 at 11:01 AM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Start giving me C notes and I'll give ya change...bout 30 cents or so.
  2. May 11, 2012 at 2:34 PM
    BradyT88
    BradyT88 Well-Known Member
    Dead thread... So have some funnies:D
  3. May 11, 2012 at 2:52 PM
    BradyT88
    Found your new Taco Chris. (I know you already saw it, just wanted to show the other guys. haha)
    You have a good eye Chris. I completely missed the tire, but damn there is just so much to stare at on this thing. haha
  4. May 11, 2012 at 3:04 PM
    BradyT88
    It has a double hood skewp already. haha
  5. May 11, 2012 at 3:05 PM
    BradyT88
    :woot:
  6. May 11, 2012 at 3:43 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    what up threadies
  7. May 11, 2012 at 4:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    All packed. Ready to go!:woot:
  8. May 11, 2012 at 4:17 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I just gotta throw my bins in the back and I'm outta here
  9. May 11, 2012 at 4:33 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    on the way down i was 3 wheeling and tipping. after backing up and re adjusting getting down my drivers rear was still almost a foot in the air
  10. May 11, 2012 at 4:35 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you look like you're already in the desert
  11. May 11, 2012 at 4:37 PM
    BradyT88
    Just got back from a run. Will shower, eat dinner then back to packing. haha. I'm being pretty sluggish about getting stuff together for some reason.
  12. May 11, 2012 at 4:38 PM
    BradyT88
    That is pretty much what all of southern Idaho looks like.
  13. May 11, 2012 at 4:39 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I've only been there once and that was to drive though it.
  14. May 11, 2012 at 6:49 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    God Damn it I can't get these stupid u joints apart!
  15. May 11, 2012 at 7:00 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you drop the drive shaft out and work them on the bench?
  16. May 11, 2012 at 7:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. Literally been hammering on just the first one for like an hour. It wont budge. Cap is sticking only likemaybe an 1/8. Not enough to grab it and pull it
  17. May 11, 2012 at 7:57 PM
    Digiratus
    Roaming the PNW
    The RedHead
  18. May 11, 2012 at 8:00 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yepp tried them both...
  19. May 11, 2012 at 8:36 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  20. May 11, 2012 at 8:43 PM
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Try using the vice and a couple of sockets to press the u joint out of the ears. One socket will be big enough for the cap of the u joint to fit into the other socket is small enough to fit through the ear.
