Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 30, 2012 at 12:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haven't you learned your lesson yet?
  2. May 30, 2012 at 1:05 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    im quoting my self to bring this over to the next page so you fucks see it:D
  3. May 30, 2012 at 1:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    id tow it Mark.
  4. May 30, 2012 at 7:48 AM
    BradyT88
    BradyT88 Well-Known Member
    It should be light enough for the pickup and it's only 40 miles. If you have the transmission cooler then it shouldn't be a problem what so ever. If you don't it's only 40 miles, I still doubt it will be a problem. If you are worried you could let it rest at the top of the hills to cool the tranny.
  5. May 30, 2012 at 7:48 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    You're an auto tranny? You're going to want to get a transmission cooler before towing anything.
  6. May 30, 2012 at 7:48 AM
    MTgirl
    Weesa
    Damn you Brady!!! :mad:
  7. May 30, 2012 at 8:05 AM
    BradyT88
    Too slow;):eek: haha:cool:
  8. May 30, 2012 at 8:22 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Ben, looks like you didnt fully remove the TB. I fully removed mine and fully cleaned both sides and into the mainfold where it was even dirtier. I would suggest taking it completely off and doing a full clean if you havent.
    I found the idle and start up to be the most noticeable improvement.
  9. May 30, 2012 at 10:26 AM
    BradyT88
    Maybe I should check out the throttle body on my hyundai after it's little episode. Hasn't had another one yet, but I have noticed that 1 out of every 3 or 4 starts it takes a little bit longer than usual to start and it sputters a little for about a sec before it goes to a nice idle.
  10. May 30, 2012 at 10:29 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    you broke your hand and rolled your truck have you learned yours.:rolleyes:
  11. May 30, 2012 at 11:58 AM
    MTgirl
    Weesa
    Happy Birthday Connor!
  12. May 30, 2012 at 12:39 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I just disconnected the vacuum hoses, removed the 4 bolts that hold it on, and pulled the throttle cable off the adjuster mount. there was enough slack in the cable to get it off the bolts. I didnt get it completely off but enough to clean it thoroughly
    Happy birthday!
  13. May 30, 2012 at 1:58 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Wait its your birthday? Happy birthday old man
  14. May 30, 2012 at 4:37 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Happy birfmas Connor
  15. May 30, 2012 at 6:07 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I would never trust a retread for wheeling, heard wayy too many horror stories
  16. May 30, 2012 at 6:40 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    lol'd for personal pleasure
  17. May 30, 2012 at 6:49 PM
    bitejr138
    bitejr138 CTID
    Kelly
    St. Maries, Idaho
    Sounds like an excellent plan! Cheers for your birthday... :cheers:
  18. May 30, 2012 at 6:58 PM
    bitejr138
    bitejr138 CTID
    Kelly
    St. Maries, Idaho
    Wasn't your ol' man kinda like that too...or was his only complaint about not having room service? :rolleyes: Either way, he was still a trooper...
  19. May 30, 2012 at 8:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Happy birfday buddy. :cheers:
    I stopped celebrating mine a while back. Stuck on 39 :rolleyes:
  20. May 31, 2012 at 12:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol maybe like 10 years ago.
    KM2s are known for 45k min. they last a long time. the KM1s would do 60k..
    however..i have no argument for the MPG :p lol
    i think i might end up with ATs for my 35s..just cheaper..
