Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. May 31, 2012 at 6:20 PM
    lunchboxhero
    lunchboxhero Out for a rip eh!
    Aleks
    Boise, Idaho
    I'm not mark.
  2. May 31, 2012 at 6:20 PM
    lunchboxhero
    Aleks
    Boise, Idaho
    physically 18
    mentally.... Shit...
  3. May 31, 2012 at 6:21 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    3
  4. May 31, 2012 at 6:22 PM
    lunchboxhero
    Aleks
    Boise, Idaho
    6 on good days
  5. May 31, 2012 at 6:23 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you forgot to divide by 12 :rolleyes:
  6. May 31, 2012 at 6:24 PM
    lunchboxhero
    Aleks
    Boise, Idaho
    :rofl: :)
  7. May 31, 2012 at 6:49 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    B18B? Si? Type R?
  8. May 31, 2012 at 6:57 PM
    lunchboxhero
    Aleks
    Boise, Idaho
    b18b1, ls non vtec.
    Plan onbuying a blown up b18c/1 to build over the summer for high compression
  9. May 31, 2012 at 7:08 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    good engine. Had a 96 honda just had a h22a, non vtec. All my buddies had integras or preludes or the lke so learned a bit about them.
  10. May 31, 2012 at 7:21 PM
    lunchboxhero
    Aleks
    Boise, Idaho
    still a fast motor :)
    Wish I could've got a truck but mark claims that this fits me MUCH better.
  11. May 31, 2012 at 7:28 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Turbo that shit
  12. May 31, 2012 at 8:00 PM
    BradyT88
    BradyT88 Well-Known Member
    Nice! Hope you enjoy it:D
    U joints are now greased and the noise is unchanged. Think if I just take the rear driveline out and go front wheel drive and see if the noise goes away or not that would eliminate it being either the carrier bearing or the u joints right? and would leave either the diff or the tranny?
  13. May 31, 2012 at 9:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thank you sir
    That would be a bit extreme and wouldn't tell you anything about the tranny, not that I suspect the tranny.
    Is your drive line a straight line from the back of the tranny to the rear diff? Or is there an angle in it, right at the carrier bearing?
  14. May 31, 2012 at 9:52 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    hey, i happen to like it too, as i am also a fan of the low and i think its a pretty clean all around good lookin fun little car. atleast when you take a turn it stays planted, unlike say my truck which rolls about 45 degrees in each direction. Its fun to play with.
  15. May 31, 2012 at 9:57 PM
    BradyT88
    I don't expect the tranny either. haha. I just put that in there for Monte. I thought that if I pull the drive line and it still makes that noise then it is most likely the diff, if the noise is completely gone then it is most likely the drive line.
    and yes there is an angle at the carrier bearing.
  16. May 31, 2012 at 10:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you disconnect the drive line and the noise goes away it might be telling you something but it wont be about the diff. You've already proven that the noise goes away when you stop applying engine torque.
    Lower the carrier bearing. straighten out the drive line.
  17. May 31, 2012 at 10:18 PM
    BradyT88
    I see. Guess I will give that a try then.
    Hey Adam, I guess I will take that carrier bearing drop kit. I'll pay the shipping for it. I have a question though. How do you have one? Did it come with your lift?
  18. May 31, 2012 at 11:06 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I bought it with my lift but i don't have a carrier bearing so it just sits under my passenger seat waiting for a new home.
  19. Jun 1, 2012 at 12:04 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That will help a bit I'm sure. But I still think its your U joint
  20. Jun 1, 2012 at 1:36 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :jerkoff:probably!
    also im jelly of your summer job, working at a bar would be a shit ton of fun compared to my lame ass job at a grocery store.
