Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 3, 2012 at 11:28 PM
    BradyT88
    BradyT88 Well-Known Member
    I believe his OME's have a little more travel than my 5100's plus they don't let his Taco sway, like mine does when turning.
    Last I checked they weren't leaking.
    Nah! I'm in bed;) haha. Laptops are portable;)
  2. Jun 3, 2012 at 11:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Swaying is wheeling
  3. Jun 3, 2012 at 11:38 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    My front lift will swap over to the runner and for 170 bucks I can get new springs for the rear.
  4. Jun 3, 2012 at 11:49 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  5. Jun 4, 2012 at 12:48 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    two of the most simplistic forms of music..well..most sub genres lol Humans like repetition in music..thats why its so big. Jazz and blues ppl love it cause its NEVER the same any time its played
    5100s ride stiffer then Nitrochargers, least thats what the majority consensus has been..
    rear shocks swap over too?
  6. Jun 4, 2012 at 12:57 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    even the front springs can stay the same! :woot:
    the rear shocks are not swappable :( the rear on the runner is coil sprung and I already checked the part numbers no go.
    The nitrochargers have a faster rebound than the billies and more travel.
  7. Jun 4, 2012 at 1:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ahhh well close! Half a lift anyways..
    and really? maybe 2nd gens are different..
  8. Jun 4, 2012 at 1:05 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    170 bucks for a lift ain't bad plus I already have wheels and tires for it.
    Tim's willing to work with me to get a bumper/ make a bumper.
    this could be interesting.
  9. Jun 4, 2012 at 1:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i saw that.
    i gotta say tho..you'll need 35s lol the 4th gen 4runners look best with 35s..
  10. Jun 4, 2012 at 7:36 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    did you already get the 4runtard?
  11. Jun 4, 2012 at 8:07 AM
    BradyT88
    Yeah, but from what I was told, I have way more sway than I think it should have, especially since I have no weight on really stiff springs up front. Adam's doesn't sway nearly as much and he has weight on his springs, about the only difference we found that should give him less sway we found is the shocks.
    But your lift is listed to sell with your Taco?:confused:
    Well like I said I don't really understand music and art so I have to have simple;) haha
  12. Jun 4, 2012 at 10:03 AM
    BradyT88
    Diff's are ordered!!:D Should be here Thursday or Friday, but thanks to the Army I don't know when I am going to have time to swap them.
  13. Jun 4, 2012 at 10:06 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It all depends I have the parts and ability to return the truck to stock minus the sliders.
    If I can't straight trade for the 4runner then I'll return the truck to stock sell all the parts and trade a stock truck in and use the cash from the parts to make up the difference.
  14. Jun 4, 2012 at 10:22 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i wouldn't trade the truck as it is strait across! that would be a huge loss for you IMO.
    Sliders are going to make the truck not worth as much, especially since they are weld ons.
  15. Jun 4, 2012 at 10:35 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    We'll see what happens. I'm not concerned about the sliders lowering the value, whoever buys this truck will know what they are and why they are there. Besides around here these trucks sell for waaaaay more than they are worth. That 07 I posed with the CBI front bumper, Fabtech lift and 33s went for 29k with 90k on it.
  16. Jun 4, 2012 at 10:40 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ya yotas go for a lot around here too.
    good luck man! keep us posted :popcorn:
  17. Jun 4, 2012 at 10:42 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I certainly will. I have my title with me JIC. :D
  18. Jun 4, 2012 at 11:41 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    haha nice! good luck with it!
    You gonna show the new owner the pics of the truck flying?
  19. Jun 4, 2012 at 11:54 AM
    BradyT88
    You should put the flying pics and the pic of the rotor sitting on the road up with your CL ad;) haha That will help the resale value right?:rolleyes:
  20. Jun 4, 2012 at 11:54 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    HAHAHA, what a great plan!
