Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 7, 2012 at 1:10 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You can get decent travel without going through the bed, You can run the shocks outside the frame. Call mike and chat with him, he's the expert on all this mid travel stuff and could answer your questions better than me, you see what my truck looks like.
  2. Jun 7, 2012 at 1:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I wouldn't go LT Brady for the rear. The Allpros will be great for you i feel like. LT rear suspention is useless IMO unless your going full LT..JMO tho..
  3. Jun 7, 2012 at 1:12 PM
    BradyT88
    BradyT88 Well-Known Member
    I may send him some messages on here. haha. I don't want to get too involved in it yet until I get the diffs finished and see where things are at.
    Thanks for all your help and info:D
  4. Jun 7, 2012 at 1:26 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Defined engineering sua isn't LT. It's just a stock replacement spring pack that goes under the axle. All of the factory mounting points are used except for the spring perch. 11" of travel in the front and 15" in the rear is mid travel, and is a very good balance. 15" travel in the front and 20" in the rear is long travel. 24" of travel in the front and 30" in the rear is full race. This is a video of my truck with deaver aal's and stock length shocks. The difference between This and LT is about 40mph. http://www.youtube.com/watch?v=HXmvkvcLJng&feature=youtube_gdata_playerI've went from stock, to aal's, to a deaver 10 pack, to deaver h70's sua, to all pro baja leaves sua. Trust me, SUA is where it's at.
  5. Jun 7, 2012 at 1:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2nd gen. you can tell by the top shock mount. 1st gens are different.
  6. Jun 7, 2012 at 1:38 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    good. i've made a point to use it every trip out so far. ask me again in a few weeks after I go to Grand Teton park for my spring trip....I'm trying to beat my previous record of 14 moose sightings in one day.
  7. Jun 7, 2012 at 1:44 PM
    BradyT88
    Cool. If I get allpro's or Dakars and the 5100's aren't long enough I may go for those. If I do the SUA, I may need longer than 12" though, depending on what I do with the shock mounts.
    Damn! 14 in one day. My best here in Idaho is 5. Usually I am lucky if I see 1 a year.
  8. Jun 7, 2012 at 1:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That's because the mooses (moosi, mees, :confused:) are smarter than you. They know they are safe from you when in the NPs. :D
  9. Jun 7, 2012 at 2:00 PM
    BradyT88
    I believe it is mooses. haha and I don't hunt them, too hard to draw out and they are too hard to find in ID. In my area they only give out 5 moose tags a year, while they give out like 1500+ deer tags a year.
  10. Jun 7, 2012 at 2:07 PM
    MTgirl
    Weesa
    They're crawling all over the place down there. Here I'm happy if I get to see one a month.
    Safe yes, almost too conditioned to humans though.
    Can you spot the moose in the attached? He was taking a little afternoon nap when I found him....
  11. Jun 7, 2012 at 2:13 PM
    BradyT88
    He's a beauty:D
  12. Jun 7, 2012 at 2:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I only see an antler. One would assume there is a moose attached to it. :rolleyes:
  13. Jun 7, 2012 at 2:27 PM
    BradyT88
    Put your glasses on old man:rolleyes: I see ears, a brow and part of the other antler. haha
  14. Jun 7, 2012 at 2:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :pout: They are on...
  15. Jun 7, 2012 at 3:13 PM
    BradyT88
    :rofl:
  16. Jun 7, 2012 at 3:36 PM
    MTgirl
    Weesa
    He was a pretty big boy.
    There is a whole moose in there. I walked by him not once but twice before I saw him though so don't feel bad.
    :cool: But the cool people wear their sunglasses all the time now.
  17. Jun 7, 2012 at 3:44 PM
    BradyT88
  18. Jun 7, 2012 at 3:45 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Monte, u got a link to that 140 mile kokopelli trail? Its like through the desert right? If so thatd be easy. On our last desert ride we coveted 40 miles in a couple of hours. If u did it next year in spring or fall im really considering it, if its realistic on my bike haha. Have no clue how to go about this.
  19. Jun 7, 2012 at 3:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :wave:
  20. Jun 7, 2012 at 3:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Mark, check these out. Pretty good info.
    http://en.wikipedia.org/wiki/Kokopelli
    http://en.wikipedia.org/wiki/Kokopelli_Trail
