Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 8, 2012 at 9:16 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  2. Jun 8, 2012 at 9:21 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
  3. Jun 8, 2012 at 9:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The raisin will be ready I think. The front axle and ball joints have been fixed. The COs have bees sent to DSM for a rebuild. Should be back in a week or so. All that is left is the water pump/timing belt install. Not sure of the status of that yet.
    I think end of July is good. Its your call because it was my understanding that you and Ali were planning to do a whole bunch of stuff while you were here.
    The 21st and the 28th looks reasonable.
  4. Jun 8, 2012 at 9:39 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Ben is you read this or have blocked me please text me back
  5. Jun 8, 2012 at 10:18 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    I think im going to a gun range to test some new pisols tomorrow. Any recommendations?
    Hmm now i mist research. It would do it different. You would only need the one type of socket and it would fit them all.
    Lol nothing to do with welding
  6. Jun 8, 2012 at 10:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You need to test fit them on an 01-04 not your truck. Yours is designed to run 15s..Mikes truck need i think min of like 4 or 3.75'' BS to run 15s..i think..
    http://www.sears.com/shc/s/p_10153_12605_00914018000P
  7. Jun 8, 2012 at 10:32 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
  8. Jun 8, 2012 at 10:35 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea..well i said there was a wrench didn't i? not a socket. If you made a socket..you could just do the exact same design that is on the end of those wrenches..hell id wouldn't be surprised if that was next.
    Why is it then i have this weird idea in my head that you guys cant run 15s??? i swear i read that more then once..oh well. Go for it Mike! lol
  9. Jun 8, 2012 at 10:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Maybe. The brake calipers are the issue and I think the caliper is the same.
    We've had this discussion. The raisin (a '97) has 15x8 D windowed steelies on it which clear my calipers no problem.
    :proposetoast: Here's hoping that Ian's will fit the same way.
  10. Jun 8, 2012 at 10:37 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Mac it depends how much you want to spend and what caliber you're looking at
  11. Jun 8, 2012 at 10:38 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Those break is the problem, trust me, broke a couple.
    Plus you have to have 7 different wrenches for 7 different sizes. Mine is just 1 socket and would theoretically fit no matter what position you put it on.
  12. Jun 8, 2012 at 10:42 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ohhhh..saw something like that before once too..it was a wrench tho that like sorta clamped automatically around the nut. You just squeezed and turned..
    good luck making a socket do that! Plus..i don't think it would be a good idea. Cause you'd have to make it cover a range of 18mm to 8mm to be REALLY useful right?
    Well..you'd end up with a big ass socket that would not fit were a normal 8mm would..
    or are you think like some sort of shrinking wrench..
  13. Jun 8, 2012 at 10:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :thumbsup:
  14. Jun 8, 2012 at 10:43 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    so adam, ben. I was thinking that this winter, I want to get a couple of friends and drive up to CDA for a couple of days to ride schweitzer. Are there any other good resorts on that same level near by that would also be good to go to? Either way I we could come up and hang with you guys, ride with you guys, and or course...drink...lots...of apple juice:cool:
  15. Jun 8, 2012 at 10:44 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    If you find something like that let me know lol.
    Its a different concept of doing it. But yea you could do different lengths of the handle if needed. And no squeezing and turning just push on.
  16. Jun 8, 2012 at 10:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    So wait..are you thinking like the socket? or just the ratchet?
  17. Jun 8, 2012 at 10:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  18. Jun 8, 2012 at 10:47 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i must have missed this discussion, but has brady locked in a plan and if so what is it? I heard SUA so i think he wants lots o long travel?
  19. Jun 8, 2012 at 10:48 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Like the socket. Like take a socket wrench, then take your normal socket off, put this one on, and boom never need another one again.
  20. Jun 8, 2012 at 10:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep thats what he is doing Mark..which im not sure why he would want a UA leaf pack..for crawling..
