Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 8, 2012 at 10:50 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ehhh..i don't see this working.
    Like i said..it would have to be big enough for an 18..and i assume change all the way down to an 8 on the inside of the socket.
    Sounds good..BUT..the outside would still be 18mm..which won't fit were most 8mm bolts are..
  2. Jun 8, 2012 at 10:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    15" Toyota wheels will fit fine on the 01-04s. It is some aftermarket wheels that don't. Has to do with the design of the wheels. With D windowed wheels, it is the way the D windows are "punched out" during manufacturing. The metal lip will hit the caliper with some. That is why I was real surprised when Mark's worked on mine and pleasantly surprised when Ian's clear his calipers.
  3. Jun 8, 2012 at 10:51 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    was that sarcasm....
  4. Jun 8, 2012 at 10:54 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Ahh I see your point with that, but in many cases like that you can fit a smaller length ratched with the same socket so you could have shorter ones.
    Obviously it wont work in every case, but any case that a normal socket would, this would as well.
  5. Jun 8, 2012 at 10:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ahhhh..okay. That makes more sense.
    No. I honestly don't get why you would want and Under Axle leaf pack for crawling..by by clearance. You'd have to come up with some sort of skid for the U Bolts. taking away even more clearance.
    yes i know LT guys crawl sometimes..but i would never put a leaf pack under the axle if that was my plan.
  6. Jun 8, 2012 at 10:56 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    True. Or you could just resort to like three sizes fit all. Like 22-18mm and 17-14mm and 13-8mmm..or i bet 4 sizes would be better.
  7. Jun 8, 2012 at 10:58 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Though of that too.
    Hmmm I must get time to draw this up
  8. Jun 8, 2012 at 10:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ya id me interested in what your thinking exactly.
    MIKE!!!!!!!!!!!!!!!!!!!!!!!!!
    I have my stock leafs still in Mark still is looking for a set. He asked me to check if i had mine and i do. Please let him know! I be more then happy to ship them to him if he paid and slip a tiny sum of money to me :) like small..cause im sure shipping will be like 80-90 bucks :eek:
  9. Jun 8, 2012 at 10:59 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    oh, gotcha. well if he is going for a SUA full LT set up crawling is kind of not that realistic.
  10. Jun 8, 2012 at 11:00 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Had Rouge before and love it! I have some friends from th Corps out there in Oregon, and I have a feeling I'll have to take a trip out there soon!
  11. Jun 8, 2012 at 11:01 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Its not undoable..but not ideal yes..
  12. Jun 8, 2012 at 11:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Are you thinking of something like the gator grip type of design?
  13. Jun 8, 2012 at 11:04 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    i didn't mean it wasn't doable...but ya wrong end of the spectrum.
  14. Jun 8, 2012 at 11:04 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That looks cool..
  15. Jun 8, 2012 at 11:05 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    FUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
    yes...
  16. Jun 8, 2012 at 11:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea.
    Idk..Brady..i think there are other ways to get just as much travel without UA leafs.
  17. Jun 8, 2012 at 11:07 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wonder how much torque that thing holds tho Mac..
  18. Jun 8, 2012 at 11:07 PM
    mh.meier
    The Doctor
    Commiefornia
    Aint no thing man, we'll get through it. And come on, dont leave us in suspense. dont make me drive up there!
  19. Jun 8, 2012 at 11:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It is an interesting design... Sorry Dude, I hope I didn't ruin you evening. :eek:
  20. Jun 8, 2012 at 11:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mike did ya see my previous post.. :eek:
