Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jun 13, 2012 at 9:21 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The soundproofing project has begun. Overkill of course, but I'm not spending another summer in a spam can with no interior.
  2. Jun 13, 2012 at 9:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I haven't done it so I can't say for sure but I've read that is it simpler to lift the bed off and work on the exposed pump. Supposedly, dropping the fuel tank adds a few complexities. That is why I asked Ian what he did.
  3. Jun 13, 2012 at 9:24 PM
    BradyT88
    BradyT88 Well-Known Member
    dynamat? I have some cheap knock off stuff in the trunk of my car. The subs made the metal rattle too much.
  4. Jun 13, 2012 at 9:28 PM
    BradyT88
    Granted it's not a toyota, but my dad has had to put 2 fuel pumps in his GMC Sierra and they always drop the tank.
    Not sure what all is involved in dropping it, but on my taco it is held in my pins, so it can't be that had to drop it.
  5. Jun 13, 2012 at 9:34 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    2 packs of Rammat Bxt-2 and 6 yds of ensolite. Also ordered some Kevlar to wrap the cage with (it gets hot and burns you in the sun) and 20yds of carbon Kevlar to make a dash and some other, umm, projectile absorbing stuff out of. The goal is a quiet interior with level II ballistic protection. We'll see how it turns out...
  6. Jun 13, 2012 at 9:47 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    My supra had an access point in the back for the pump. But we dropped the tank anyways
  7. Jun 13, 2012 at 9:48 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Chris! How's it going man?
  8. Jun 13, 2012 at 10:09 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mixing is going good. Have a full album to do and another project too. Working 4 jobs so yes I'm busy haha
  9. Jun 13, 2012 at 10:25 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I didn't remove the bed but yes it would have made it alot easier. Good thing I'm pretty small cause I barely fit under there. Never buy a non oem fuel pump. Im not sure how much the oem pump is but I paid $140 for an aftermarket pump. I can't remember the brand but it sucked. Almost all made of plastic and the electrical connectors didn't match. So I had to splice new wires and connectors.
    This was my view for 3 hours...
  10. Jun 13, 2012 at 10:27 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    My old corrola too. Just pull out the rear seat and pull out the pump. So easy. Taco... Not so much
  11. Jun 13, 2012 at 10:53 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    cut a hole in the bed? :notsure:
  12. Jun 13, 2012 at 11:00 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thats seems out of my league for now. Ill just stick to dropping the tank or maybe ill try taking the bed off next time.. if there is a next time:eek:
  13. Jun 13, 2012 at 11:03 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wow. Can't imagine doing it that way without a hydraulic lift.
  14. Jun 13, 2012 at 11:08 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I would have used a lift but it was occupied. I had a floor mat, 2 floor jacks and thats it.
  15. Jun 13, 2012 at 11:18 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    wow not even a wrench? Damn Ian, you canadians are hardcore.
  16. Jun 13, 2012 at 11:20 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Good day Sir! what's new? get any more parts?
  17. Jun 13, 2012 at 11:25 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I'm working on it. I'm going back to stock in 2 weeks. then the truck is going on my buddies lot. I'll be driving the exploder till it sells.
    did ya get cleared by the Docs yet to get behind the wheel?
  18. Jun 13, 2012 at 11:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You keeping the goodies or no?
  19. Jun 13, 2012 at 11:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    LOVE that film.
    Can relate to it a lot actually as i have a lil bro and we both wrestle lol Start MMA here soon tho!
  20. Jun 13, 2012 at 11:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
