Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 15, 2012 at 10:03 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I see. Yeah 18' 7k car haulers are something we dont normally carry. Its not very common that someone needs 18'
    As much as it kills me to say this, check out Fox Trailers. They are one of our biggest competitors across the line.
  2. Jul 15, 2012 at 12:36 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Called it! I lost my drive brake light when i did mine....
  3. Jul 15, 2012 at 12:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I don't care, your not going to soup up a 2jz in that ugly ass lexus. The only Lexus worthy of a 2jz is a Soarer.
    Still and ugly ass car.
    what trailer did you use for Mike's rig??
  4. Jul 15, 2012 at 12:39 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Looked like a 16'
  5. Jul 15, 2012 at 8:45 PM
    The Raisin
    The Raisin Well-Known Member
    Mark
    Spanaway, WA
    streetqueen
    Badlands front bumper with a Smittybilt 8K winch, synthetic winch line. Demello sliders and bedbar. Custom rear bumper. Custom skid plates. Flex-a-lite tranny cooler with fan mounted in bed. Bilstein 5100's with SAW coils, AllPro UCAs, NW offroad rear springs (garbage), 4.88s and front and rear lockrights. Lots of custom sheetmetal work.
    I used my bosses 16' car trailer. !6" feet works but I would much rather have a 18' There is a local place near my work that sells 7k 18'. I am always on the look though.
  6. Jul 15, 2012 at 10:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Got my new (to me) lightforce 170s all wired. Took it out on a dark road to see what is up.
    Low beam headlights only.
    Low beams with the 170s without any lens covers.
  7. Jul 15, 2012 at 10:25 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    holy shit your low beams are incredible!
  8. Jul 15, 2012 at 10:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Looks good mike.
    Would be better if they were 240s :p
  9. Jul 15, 2012 at 10:28 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Still need to play around with aiming them correctly. Here is another set.
    Low beam only.
    Low beam and 170s.
  10. Jul 15, 2012 at 10:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My low beams are pretty good. The '02 headlight is a much better design than the '96 & '97. I also have great aftermarket bulbs in them.
  11. Jul 15, 2012 at 10:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ya I found that on my trip back from Moab my 240s where pointed up higher then normal due to all the weight in the back. Seemed to look better to me then when they were kinda how you have em. Try pointing them up higher see how ya like it
  12. Jul 15, 2012 at 10:52 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    don't worry I'm not buying the lexus, RWD would blow in the winter.
  13. Jul 15, 2012 at 10:57 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    drift machine!!
  14. Jul 15, 2012 at 11:17 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    accident prone...
    TDI Jetta or Camry
  15. Jul 15, 2012 at 11:21 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    not that much better:p
  16. Jul 15, 2012 at 11:37 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    suck it ginger
  17. Jul 15, 2012 at 11:40 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    doesn't matter I'll put them on my next ride.
  18. Jul 15, 2012 at 11:42 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ouch, such hostility
  19. Jul 16, 2012 at 12:01 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Mark buy my truck and make your truck 8x8, 4 clyx2, or weld mine on top of yours and if you roll you can keep going ;)
  20. Jul 16, 2012 at 12:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ben..you better be there
