Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Jul 19, 2012 at 1:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ya...but nothing for Toyota...
  2. Jul 19, 2012 at 1:42 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    That is true
  3. Jul 19, 2012 at 1:44 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    They make LED headlights for 6X9 headlights for our 95-97 trucks
  4. Jul 19, 2012 at 1:45 PM
    memario1214
    Colton
    Missoula, MT
    There are also ones out for Jeeps too that I just remembered
  5. Jul 19, 2012 at 1:48 PM
    BradyT88
    BradyT88 Well-Known Member
    Since we are on the topic and Colton seems to know his stuff, what are some good headlights for a 2nd gen. I browsed around a little several months ago for some HIDs but didn't find much. I know too little about head lights... I just know that mine suck...
    What I did find is that I think some bi-xenons would be sweet:D but I have no idea what all is involved to do that kind of an upgrade...
  6. Jul 19, 2012 at 1:53 PM
    memario1214
    Colton
    Missoula, MT
    So... Are you asking me to break down all of your options: Pros, cons, etc? lol first off, what's your budget?
  7. Jul 19, 2012 at 1:59 PM
    BradyT88
    Haha. Not sure what my budget would be at the moment.
    How about just a brief run through of what it would take to install some HID's or bi-xenon's? Like I believe I have to get ballast's and the bulbs, but would I also have to upgrade to a whole new housing or could I just use the factory?
    I don't need a detailed run down of this brand/model is good as this may not be something I do anytime soon.
  8. Jul 19, 2012 at 2:35 PM
    memario1214
    Colton
    Missoula, MT
    Alright Brady... Here it comes. I'll give you a summarized rundown of the different options (though I should put together a detailed version at some point or another)
    Stock Housings & Stock Bulbs: With the stock setup you will get decent foreground coverage and width in the beam. In foggy or tough conditions they do well to cut through the crud due to their lack of UV output.
    Stock Housings & Aftermarket Bulbs (75w+): I have seen some good things from this setup. A guy I know is running 75/100w bulbs in his Tacoma and I honestly was pretty impressed. They put some great light down and the weak points are supported by the additional output of the bulbs. I think he even got them at NAPA or somewhere like that. They don't blind when behind you on the road either. For >100 bucks you can't really beat this. Most questionable thing is the longevity on a halogen bulb pushing that kind of wattage through it. I say plan to replace bulbs yearly, though that is entirely a guess.
    Stock Housings & HID Bulbs: I don't even know what to say about these babies. I had a set of drop-ins and ran them for about a year. I had 6000k bulbs and I actually liked them. I thought they put out pretty good light and thought they looked good as well. I had people bitch at me often about how they look inside the cab (they reflect off of street signs bad because HID bulbs put out UV light) as well as driving against me. If you are gonna go this route, for the love of all things holy, please make sure the bulb has a shield on it and you go 4300k bulb temp.
    D2S Projector: Having been there, done that, I say don't spend the money. Yeah, they look cool and all, but the output just doesn't justify the ~$400 to do the retro correctly. They have a solid cutoff, but the light that is under the cutoff just isn't all that impressive. For a mini retro, the H1 is a much better option.
    FX-R Projector: One of the best projector setups you can get for a vehicle like ours. Very sharp cutoff and very intense light under the cutoff. Definitely better than the stock setup. My only complaints thus far is that they wobble a bit on rough roads (may be due to the fact that the projector is heavy in there or lackluster installation. I did not assemble the set that I am running) and the fact that there IS a cutoff. If you spend a lot of time offroad, projectors are probably not the route for you. I like light everywhere when I am offroad... And for one reason or another when I am out, I don't feel like projectors give me as much lighting all over as they are such a defined beam. Better than stock? Of course. Worth the money? Maybe... If you a) like the retro look b) don't offroad a lot or c) supplement them with spot lighting.
    So there you go Brady. Little rundown of the possible setups for you
  9. Jul 19, 2012 at 2:48 PM
    BradyT88
    I see. Thanks. That helps:D I just looked up the FX-R 3.0 and it says they are bi-xenon. I can't remember for sure, but I thought the non-bi xenon bulbs were basically stuck on dim, while the bi-xenon's have both dim and bright. Wouldn't setting them to bright eliminate the cutoff?
  10. Jul 19, 2012 at 3:45 PM
    memario1214
    Colton
    Missoula, MT
    Okay. Bixenon.
    Bixenon pretty much means that there is a relay that designates hi-beam and low beam for a HID bulb. For drop in bulbs, the relay sends a signal to the bulb to seat differently within the housing therefor moving the light beam upwards. For a projector, the relay tells the shield in front of the HID bulb to drop or be up. So yes, setups that are not bi-xenon are always on one beam pattern. This would be what you want if you had a vehicle that used different bulbs for high and low beams for example.
  11. Jul 19, 2012 at 3:57 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    False
    False
    False
    True lol I have the link on my home computer I'll send u it if.you want Monte
  12. Jul 19, 2012 at 3:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Guess who just got a rear bumper :D
  13. Jul 19, 2012 at 3:59 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  14. Jul 19, 2012 at 4:07 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I did bitches!
  15. Jul 19, 2012 at 4:12 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    NO WAY
  16. Jul 19, 2012 at 4:19 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    It came with my new car
  17. Jul 19, 2012 at 4:28 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    is it a plate bumper? for your car? thatd be sick breh
  18. Jul 19, 2012 at 4:29 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    yes paper plate bumper broseph
  19. Jul 19, 2012 at 4:35 PM
    memario1214
    Colton
    Missoula, MT
  20. Jul 19, 2012 at 4:47 PM
    BradyT88
    Adam!!! Details of said vehicle!!! That was a cool drop into the conversation though:thumbsup:
    I had heard of the shield moving version, not the bulb moving version. Are your bulbs xenons? bi or non? Just curious since you said you don't really like them for offroading.
