Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Aug 30, 2012 at 10:34 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I don't see anything in that discussion that makes me think regearing isn't the way to go. I am running 33's ATM and the truck is definitely asking for gears on the pavement. It wants to downshift way to much.
    I have not tested this on the trail yet but but I have driven my friends '97 with the v6 and auto and 4.88s. On the trail that is a sweet combo.
  2. Aug 30, 2012 at 10:38 AM
    Digiratus
    Roaming the PNW
    The RedHead
    There is always a risk of breaking a front axle every time you get off pavement. Being locked up front definitely adds stress to the front diff and axles tho. But yes, there will be the temptation to use it if I have it. :D
  3. Aug 30, 2012 at 10:57 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well..its like an ultra get unstuck button. When i have lockers i will never have them on unless i think im going to need it on a particular section id have the on. Otherwise they will both stay off till needed and front wont go on ever unless super needed..but ill have 35s by then anyways, so ill have to be even more ginger with tundra axles.
  4. Aug 30, 2012 at 11:10 AM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I know ou guys are over the regearing chit chat but I run 33's on mine and dont go over 2K RPMS until I am at 75ish MPH. If I cruise at 65 I am just under 2K RPMS. That seems to contradict Brady's reply I think unless you are MT Brady?
  5. Aug 30, 2012 at 11:17 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Brady's are just over 33'' since his are 255/85s and yes they are a MT.
    what size is your exactly?
  6. Aug 30, 2012 at 11:19 AM
    mh.meier
    The Doctor
    Commiefornia
    285's but they arent that much smaller than his. Didnt think it would be that much of a difference.
  7. Aug 30, 2012 at 11:20 AM
    mh.meier
    The Doctor
    Commiefornia
    Nad I have the KM2's so I am MT also
  8. Aug 30, 2012 at 11:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    they are slightly shorter, but yes, not much. Think yours are like 33.2 and Brady's are 33.8?? :notsure:
    but what is odd is his are like 10'' narrow and yours a 11''..and wider tires tend to bog down motors and what not much more.
  9. Aug 30, 2012 at 11:22 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Always :thumbsup:
    I have been known to run the TRD locker on sections of trails where it isn't always required only because I believe it doesn't hurt to have it on. This is not the case for a front locker. That would be an "only as absolutely needed" situation for several reasons. In fact, from here it would seem like it would only get turned on after an attempt is made without it.*
    * I reserve the right to change this position without notice. :D
  10. Aug 30, 2012 at 11:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    well hopefully you never have to change a CV on the trial man!
  11. Aug 30, 2012 at 11:25 AM
    mh.meier
    The Doctor
    Commiefornia
    Thats exactly why I think its odd. Even if his are taller is the wicth that really gets you. Wierd. I dunno then.
  12. Aug 30, 2012 at 11:26 AM
    Digiratus
    Roaming the PNW
    The RedHead
    For BFG's the posted numbers are:
    255/85-16 is 33.3"
    285-75-16 is 32.7"
  13. Aug 30, 2012 at 11:30 AM
    mh.meier
    The Doctor
    Commiefornia
    That still seems to me to be a small diference. Not enough to justify the difference in RPMS.
  14. Aug 30, 2012 at 11:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    thats a half of an inch..pretty big actually.
  15. Aug 30, 2012 at 11:38 AM
    mh.meier
    The Doctor
    Commiefornia
    Yeah I get that. Still, seems like a huge increase in RPMS. It is what it is I guess.
  16. Aug 30, 2012 at 12:02 PM
    BradyT88
    BradyT88 Well-Known Member
    Those are the rpms for 4.88 gears in a second gen. The factory gears match what you are saying: Just over 2K at 75mph.
    My tires are supposed to be 33.07" tall and 10.04" wide. At 60 psi I measured them at exactly 33" (granted I can't measure to that kind of tolerance with a tape measure, but it looked to be almost spot on the 33" mark).
    You're tires are supposed to be 32.83" tall and 11.22" wide. So they probably measure somewhere between 32.5" and 32.8" tall.
    Tire width won't affect your rpm at different speeds, it will just affect how hard the motor has to work to maintain that speed.
    With the factory gears I never had a lack of power by any means. I could go from 75-90+ in no time and pull hills easy, it just required a downshift just to maintain speed at times let alone accelerate at all and that raped fuel economy driving in 4th on the freeway.
    It would vary between the motors, but clearly the 4.0L doesn't make enough power at 2Krpm to handle the 75mph with oversize tires very well.
  17. Aug 30, 2012 at 12:08 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Last year in moab i took out spiders not axle shafts so the arb is deffinatly a weak link fix. axles can be changed in about 20 min on the trail and cost $75 for a new one so yeah id much rather break axles than the diff.
  18. Aug 30, 2012 at 12:12 PM
    BradyT88
    Yep. Piece of cake. Just make sure you have some spares and some extra diff gear oil:D
    Hey Konsta do you have a cool puller to get them out? Or do you do it the old fashion way with a punch and a bfh and a prybar?
  19. Aug 30, 2012 at 12:16 PM
    BradyT88
    Oh my bad. I had the wrong tranny. The 1st gen 4spd autos have a 0.705:1 overdrive gear.
  20. Aug 30, 2012 at 12:16 PM
    BradyT88
