Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 4, 2012 at 8:26 PM
    BradyT88
    BradyT88 Well-Known Member
    I am hoping that some good turbo kits come out by the time I have the funds for boost:D
    That is a good way to go. Then add gears and a front locker after that:D Once you have that crawl box, traction will start to be an issue on the harder trails.
    On a side thought, I wonder how boost and a crawlbox get along. With my 4.88 gears and a 4.7 geared crawlbox I would be hitting almost 3K rpm at 1 mph in 1st gear. I don't know numbers but since S/C's are known for starting boost earlier than turbos I'll best you would have some boost going by 3K.
    I'd probably have 150+hp at the wheels at 1 mph instead of what, 50 hp or so. Not sure what the motor output is at 800ish rpm. haha
  2. Sep 4, 2012 at 8:58 PM
    BradyT88
    I like the crawlers:D and I started with 3.73's... Unless the motor holds back really well it wouldn't take much to hit 1 mph which would put me in the ball park of 3K rpm.
    Also I wish I knew someone close with a crawlbox in an auto. I'm still curious how they will work with the torque converter. I'm thinking I will need throttle to keep it moving, unlike you guys who can just let the clutch out and go.
  3. Sep 4, 2012 at 9:05 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Front and rear lockers on a bone stock tacoma would get more places than a three wheel drive built crawl boxed taco. The single mod that gave me the most crawl capability is the front locker (already had a rear Elock). I don't even see the need for lower gearing than a stock T-case to be honest with you, but I'm not a rock jockey. I hit the crawling trails as a way to get somewhere, not intentionally dive into a boulder patch. I just think if I'm going slower than I can walk then I'll park the truck and get out and walk, lol.
  4. Sep 4, 2012 at 9:24 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Sweet!!! Welcome to renting ;)
  5. Sep 4, 2012 at 9:28 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Same with me. Im hoping to score a 4:10 elocker for the rear. Wont be putting a front locker on it. No point. If i want to do trails that require a front locker, ill just buy a old toyota and sas and lock the fuck out of it.
  6. Sep 4, 2012 at 9:47 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
  7. Sep 4, 2012 at 9:55 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    thats just gross
  8. Sep 4, 2012 at 9:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    More :stirthepot: eh? You got $10K available? :facepalm:
    The fear of breaking CVs? You can buy a lot of CVs for the difference is cost. :crazy:
  9. Sep 4, 2012 at 9:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :gossip: he's not renting. He is now a homeowner.
  10. Sep 4, 2012 at 10:00 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :gossip:no
    lol
    wait
    sure
  11. Sep 4, 2012 at 10:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yes i agree..unless you got to 35s..in which case just regearing to 4.88s keeps it about the same ratio as 33s on 4.10 at least thats what i have found..
    :der:
    What?? are you kidding me?? front locker fuck yea! just cause your going all "expo" now doesn't mean it becomes that much least capable..Front locker for sure down the road! knarly trails man!
    Fuck that. Just get the front locker for the love..then you can just take the Tacoma EVERYWHERE.
    what im gonna do. It'll be the best of both worlds. Ill have crawling and lockers and all expo stuff and LT..can't go wrong with that combo. Cause Yes, expeditions are VERY fun! BUT..so is doing the hardcore crawling trails so why not do both?
    Otherwise Ben..you might as well pass on the skids and rear bumper and just get the ARB and leave the truck as is and stick to roads like Lolo and such. That whole trip there was nothing a stock rig couldn't do..so..why not just get all the expo gear now and save money by passing on all the trail gear? :stirthepot:
  12. Sep 4, 2012 at 10:02 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    10K?? :der: for a Supercharger?? Wth Mike haha
    and i agree. So what your at risk of breaking CVs. If you drive the lockers right..you won't break a single one.
  13. Sep 4, 2012 at 10:06 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    :confused: Soooo... you have a mortgage now??
  14. Sep 4, 2012 at 10:07 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    god no, fuck that!
    know what is REALLY annoying though? none of our vehicles will fit in the garage...so we gotta find something to do with it
  15. Sep 4, 2012 at 10:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    10K is about what it would end up costing to do what mr. :stirthepot: suggested. SC and taco box combo
  16. Sep 4, 2012 at 10:13 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    So then you ARE renting
  17. Sep 4, 2012 at 10:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    start a garage band :rolleyes:
  18. Sep 4, 2012 at 10:15 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ya, mike is either :rasta: or more likely :drunk:
    we will put on shows for the neighbors! :rockband: Im the lead singer lol
  19. Sep 4, 2012 at 10:18 PM
    BradyT88
    10k for an s/c and crawlbox. Haha
    And the front locker is quite possible the best crawl rig mod for making your rig more capable next to the rear locker. I'm hoping to pick up some spare cvs before moab just in case but I'm not too worried about breaking one. Its all about wheeling smart and odds are against you breaking a cv.
  20. Sep 4, 2012 at 10:19 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    SO! you are going on some gnarly trails then since you have dual lockers and will have armor right?
    also, shoulda just gotten a trac yo
