Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 9, 2012 at 11:18 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    No, viair 90
  2. Sep 9, 2012 at 11:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea thats not a pump id mount in the bay.
  3. Sep 9, 2012 at 11:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    this ^^ The hose from the pump is only 2-3 ft long.
    The unit itself is small enough to fit under the hood. You would have to modify the hose coming out of the pump to be able to do it that way tho.
  4. Sep 9, 2012 at 11:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could just do a quick disconnect and get a wound up hose seperate..id rather have an ARB tho if your gonna do that. or something with more balls.
  5. Sep 9, 2012 at 11:34 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  6. Sep 9, 2012 at 11:46 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    I remember reading about those, but heard that was something negative about them? Would be very nice tho.
    :eek:
    Hi
  7. Sep 10, 2012 at 6:33 AM
    BradyT88
    BradyT88 Well-Known Member
    My ARB is nice but I wish I woukd have bought the bigger one. It still takes a while to fill up tires. Remember filling up using Bens after 7 mile? We would lock the hose on, BS for a few minutes, and then check it.
  8. Sep 10, 2012 at 6:37 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Ive ran on board air before. twin via air 500's but they still aren't that fast.. i think my next one will be the arb comp. but the big one.
  9. Sep 10, 2012 at 7:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The dual one looks sweet. Freakin expensive tho..its more pricey then a 20lb CO2 setup..which would do all our tires in under 3-4 mins including getting a hose out to do it and putting it away. Its soooo fast.
  10. Sep 10, 2012 at 8:10 AM
    Digiratus
    Roaming the PNW
    The RedHead
  11. Sep 10, 2012 at 8:29 AM
    BradyT88
    The big one is the one I wish I would have got. 100% duty cycle (although I've never had an issue with my 50%) and just over twice the amount of air at 30 psi over mine. I've heard people say you can run air tools on it, but when I looked into that it can only run some of the lower requirement ones. It would keep up with the higher tools with a tank a lot better than other compressors though.
  12. Sep 10, 2012 at 8:40 AM
    rctoy
    konstantenos
    Pocatello Idaho
    im not gonna run air tools just a locker and air up tires. maybe a blow gun every now and then but that's if i pack a spair air tank. like a 5 gallon.
  13. Sep 10, 2012 at 9:00 AM
    BradyT88
    I run ARB's medium sized compressor and it runs lockers and fills up my 4 tires in a reasonable amount of time and I have used it to blow out my air filter without a tank on it. It does fine although the blowing would go a little faster with a tank. It can keep blowing alright on its own but its not nearly as hard as it blows when the tiny tank built.into the compressor it full.
  14. Sep 10, 2012 at 9:07 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Co2 bros..Co2..
  15. Sep 10, 2012 at 9:37 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Its amazing to me that it has already been a month since we went wheeling on the magruder/lolo. Anyway, here are some pics of one of my favorite places in eastern wa, Palouse Canyon. I drove thru the area on my way back home last month.
  16. Sep 10, 2012 at 9:52 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Here are a few more...
  17. Sep 10, 2012 at 10:10 AM
    Digiratus
    Roaming the PNW
    The RedHead
  18. Sep 10, 2012 at 10:41 AM
    rctoy
    konstantenos
    Pocatello Idaho
    i wanna go there one of these days.
  19. Sep 10, 2012 at 10:43 AM
    rctoy
    konstantenos
    Pocatello Idaho
    I have a 2lb and a 5lb co2 tank but i still like compressed air. it's never runs out. and they charged me 75bucks last time i got my little bottle refilled. At that rate a comp. pays for it's self quick.
  20. Sep 10, 2012 at 12:42 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    Awesome pictures Mike. Reminds me othe the mini Grand Canyon here. Except the water, we dont have much of that.
