Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 10, 2012 at 1:47 PM
    BradyT88
    BradyT88 Well-Known Member
    I just briefly looked into people's results with a 5lb CO2 tank. I found this chart (it's for a 10lb tank though, so you divide by 2 for a 5lb tank)
    Those numbers look decent, the smallest tire on there can be filled 13 times from 10-35 psi.
    Well for kicks I did some rough estimates of the volume of our tires (They are pretty rough, I treated the tire at a cylinder and took the volume of the tire and subtracted the volume of the rim. Skinnier tires get an advantage here since I just assumed the rim was the same width as the tire to keep things easier). That 30x9.50R15 tire is ~5036". I found a post from a guy that said he can fill up the factory tire on his FJC, they are 265/65R17's, 8 times with a little air left over (it said 15-45 psi). The volume for that tire was 5284". Ben's 235/85R16's had a volume of 5453" and my tires had a volume of 6605". These numbers are pretty rough but I would imagine Ben would get 8 fills out of a 5 lb tank and I would be lucky to get 7 fills out of one.
    Most all of the posts I found from guys running 35's on Jeeps and claimed to get about 8 fills as well but they were doing much smaller psi changes like 20-30 or 15-25 or so.
    Depending on the cost to fill the CO2 tanks (they'd have to be pretty cheap), I just don't think that is worth if over a compressor, that costs me like 10 minutes in fuel at idle to fill up my 4 tires from 15psi to 40 psi.
  2. Sep 10, 2012 at 3:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If I went the CO2 route it would be with at least a 15 or maybe a 20 lb. tank. Some of the associated refill cost has to be hook up cost, not just the quantity of gas. So the difference between 5 and a 10 is not going to be twice as much for the 10.
    Prices seem to vary by they aren't anywhere near the price rctoy quoted.
    http://www.growannex.com/environmental-control/co2-equipment/20lb-co2-refill
    http://www.plantedtank.net/forums/showthread.php?t=135252
  3. Sep 10, 2012 at 3:26 PM
    BradyT88
    That grow annex has the best price if you have one nearby. Looks like the average is just over $1/lb (accounting for hook up fees).
    So based on what I found, it looks like most people can fill up 8 tires with a 5 lb tank, So a 20lb tank would get you 32 tires. At $18/refill that is about $0.56/tire.
    If my chart up top is accurate, with the smallest tire on there going from 10-25psi (I figure that is about what most of us were doing in Moab) it would cost $0.20/tire, or an extra $0.80/trail basically. That doesn't sound like much, but that tire is smaller than all of ours (about a 240/80R15) and I think that chart has estimated a bit high and that is if you get to fill it up for the cheapest price.
    Another catch here is when you go wheeling in groups, if you are the only one with CO2 it doesn't exactly save you time since you have to wait for everyone else to use their compressors.
    Also, unless you have a good regulator on it, CO2 could damage an ARB locker. They are only rated to use 90 psi and most CO2 tanks output 120-150psi. I think I will just stick to my compressor personally.
  4. Sep 10, 2012 at 3:29 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    It's cheaper to refill the bigger bottles. Y i don't know, my 5lb only cost me 40. then again my argument is i don't wanna pack around a big bottle just to save money. id much rather just have a renewable source. and only being able to fill my tires up once with my 5lb bottle according to the chart seems just pointless. Im that guy that changes air pressures alot depending on trail conditions.
  5. Sep 10, 2012 at 3:33 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Then again when i was in moab i dropped to 10 psi and didn't air back up untill i left. And gas stations down there are very acomadating with big compressors.
  6. Sep 10, 2012 at 3:41 PM
    BradyT88
    How fast were you driving on the pavement at 10psi?
  7. Sep 10, 2012 at 3:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Definitely have to have a regulator between the tank and the locker. I think this is the kit for that.
    http://powertank.com/products/sfID1/27/productID/135
  8. Sep 10, 2012 at 4:27 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    ^^ why are you not on a trail here Mister?!?! Hmmm... :cool:
    Hell....I'm still going through LAST summer's pics too!:eek:
  9. Sep 10, 2012 at 4:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Or all four of mikes and yours in the time it took to do mine :anonymous:
    You have to have a variable regulator for the lockers. They have a kit too.
    and 20lb tanks are the only way to go..or 15lb. Small tanks are pointless.
    Jerry claims his lasts all summer refilling his tires and others and the occasional use of power tools. Adam says the same.
    Trump on Expo portal has never had issues running out or filling tires or running his lockers.
    Ill make you jelly next time Brady :p haha
  10. Sep 10, 2012 at 5:41 PM
    BradyT88
    That regulator cost another $80 which you don't have to spend if you have a compressor. haha. I think it just depends on what psi's you run on and off road. I've been running 20/40psi so I don't think a 20 lb tank would last as long as someone who ran 15/25psi. If you had factory tires and ran 15/25psi, a 20lb tank might last you quite a while, but if you have 35's or bigger and are running 10/30psi, it may not last you very long... Maybe just your week in Moab at the rate we were all going and that's if you don't let your friends use it. haha
    I just found this chart on another forum: (fyi: a few guys commented that they think powertank was a little optimistic with these numbers)
    Apparently 10 psi is 10 psi and so on though. I was thinking it would take more air to go from 30 to 40psi than it would to go from 10 to 20 psi.
    This chart has your tire size on there. You could re-inflate your rig 20 times on a 20lb tank if you only do 10 psi. 10 times if you do 20 psi. Just doesn't seem worth it to me, since I have been running 20 psi changes I doubt I would get more than 25 times before I had to refill.
  11. Sep 10, 2012 at 7:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The way i am reading that graph..id get 40 refills on a 20lb tank..
  12. Sep 10, 2012 at 7:48 PM
    BradyT88
    40 tires. So 10 rigs.
  13. Sep 10, 2012 at 7:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea. still worth it IMO.
  14. Sep 10, 2012 at 8:00 PM
    BradyT88
    Maybe now on your 33's if you could get it filled for $18. When you go to 35x12.50's it drops to 8 rigs per 20lb tank. I just don't think the speed is worth the extra cost. Too each his own though. haha
  15. Sep 10, 2012 at 8:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    We shall see :cool:
  16. Sep 10, 2012 at 8:35 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I will stick with what I have. It may not be the fastest. But it's reliable. And I have filled up many trucks in one sitting and never ran out of air. So far I have only over heated it once in its life. Few mins later, back on duty...
  17. Sep 10, 2012 at 8:39 PM
    rctoy
    konstantenos
    Pocatello Idaho
    oh shit we did did about 60 running back to moab from norther moab trails.
    Ive run air comp. co2 and nitrogen. and let me tell you nothing is faster than nitrogen with right regulator.. co2 is the second fastest but if you have a good compressor and a small tank co2 isn't that much fast and in the long run if i would have just avoided the co2 tanks that i have and just stuck with air compressors i could be running 2 of the bigger arb comp. by now. it's a all in the long run type thing as far as cost goes. and as far as speed goes well sometimes when the trail has kicked your ass and your tired and wanna go home that speed is so worth it.
  18. Sep 10, 2012 at 8:40 PM
    shutterbug
    shutterbug Well-Known Member
    Cameron
    Downey, ID
    06 Blue Tacoma
    Trd intake, flowmaster exhaust, URD Maf calibrator, 3inch lift, Firestone Ride-rite airbags, Raceline 16" wheels, Fibeglass shell, carpeted bench kit, billet grill, Pioneer AVH1400DVD, Kenwood 150 watt amp, Kenwood 12" subwoofers, Access steering wheel controls
    Well I got looking at my budget and looks like I can afford my next project. So now I got a stupid question, o any of you think there would be interest on TW for people wanting custom skid plate replacements for their bull bar. With fancy designs(Toyota, Tacoma, TRD) and such? I know its not for the rock crawler folk but for others.
    Another stupid question, where can I get the Tacomaworld.com sticker?
    Thanks!
  19. Sep 10, 2012 at 8:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Most trails (except maybe the morrison jeep trail) dont drive off the cliff face. 5 feet in front of the front wheels is the cliff face that drops down to the railroad tracks about 30 feet below.
    Just because I did not show you the road I took to that lookout does not mean I was trailblazing.
    You should know me better than that by now Missy!
  20. Sep 10, 2012 at 8:56 PM
    Btnewman
    Benjamin
    Grand Junction co
    I could use some cut outs, they would have to fit my specs and be cost effective as well...
    You can get tw stickers by pm'ing tcbob and asking nicely. They are free from him
