Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Sep 14, 2012 at 11:50 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Mike.... I think you've used :angrygirl: as much as I have today :laugh:
  2. Sep 14, 2012 at 12:09 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  3. Sep 14, 2012 at 12:09 PM
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I finally got the chance to look at the shocks in the light and I found the number I couldn't see last night. The sticker on the shock says "33-186542"
  4. Sep 14, 2012 at 12:25 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    Oh i love playing in the water, and as long as i have a winch and it's not submerged im not scared to play by myself. Then again im fairly mellow in the water to i dont like to splash around to much i don't have a snorkle yet and factory air box's act just like wet try vacs.
  5. Sep 14, 2012 at 1:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea that all has bi amped system tho and crossovers. Probably just crossovers. That helps a lot. It filter the lows to the bigger woofer and the highs to the tweeter making the speaker more efficient and thus better sounding.
    right. Or you could get some component speakers for up front. That would help a lot too.
    and an 8'' sub would be plenty too. Google the JBL Stealth box. Might be something you like. i almost bought a used one. wouldn't fit my one of my subs tho.
  6. Sep 14, 2012 at 1:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :anonymous:
    mine can do that..
    6528_1030546584368_1846480219_67171_7618_6b83053061358a76428a139d8c8fe4683c66ff46.jpg
    or be like a concert hall on wheels as i like to say :cool: 6 speakers and 2 huge subs.
  7. Sep 14, 2012 at 1:16 PM
    BradyT88
    BradyT88 Well-Known Member
    6 speakers? What are your amps? I run 2 twelves on a mono and 4 6x9's on a 4 channel.
  8. Sep 14, 2012 at 1:18 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I'm doing it in your honor. I am thinking of just adding it to my sig so I don't have to go retrieve it each time. :rolleyes:
    :angrygirl:
  9. Sep 14, 2012 at 1:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea man. I have the stock speakers wired in series so the old rear is not a front speaker. So i have 4 front speakers, two 6x9s for rears(and i put them out in the bed for out door shit like at moab) and two Type X's
    i had two 4 ch amps for the front and rears. A sony 600w and 700w. I would bridge the 700w amp to get 115w RMS out of each channel to drive the 6x9s which are 100w RMS each. Then do the same for the fronts. But my 700w died cause i broke the gain knob adjusting it one day due to it being mounted at a bad angle(its the one with the blue, 600w is under drivers seat)
    so now just my 600w amp drives them all. Just haven't gotten around to fixing it.
    my sub amp is a 4000w mono block amp. Wired in parallel for 1 ohm it puts out about 2400w RMS which is great for my two 1000w Type X's.
    at Moab, the normal speakers where up about half way. Sub gain was all the way down. I had lots more to push, but didn't as it wasn't a dance party :p haha plus i don't push it that hard unless the truck is running..even doing what we did killed my battery the next morning remember?
  10. Sep 14, 2012 at 1:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    hahhahahahaha
    so thats like the ultimate TW goal..get a emotioncon named after you :p haha
    mine should be one hold a Shit'll Buff Out sign :p hahahaha
  11. Sep 14, 2012 at 1:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    an old saying goes... "be careful of what you ask for..."
    :angrygirl:
  12. Sep 14, 2012 at 2:38 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Monte I'll be in moab this year and I'll have a 270 amp alt on by then and i have twin red tops and a pair of 700Amp jumper cables so i got you this time.
  13. Sep 14, 2012 at 2:49 PM
    MTgirl
    Weesa
    :itllbuffout: [​IMG]
  14. Sep 14, 2012 at 3:38 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha nice man. Idk if ill be there, but that would be cool. Hopefully ill have dual reds too.
    HA!
    he needs to be smiling tho!
  15. Sep 14, 2012 at 3:58 PM
    rctoy
    konstantenos
    Pocatello Idaho
    speaking of which didn't you want my 130amp alt. ??
    and yeah i hope youll be able to make it Mr.TRD is going even if i have to kick his ass tie him up in his truck and have my wife drive his truck down.
  16. Sep 14, 2012 at 4:52 PM
    Digiratus
    Roaming the PNW
    The RedHead
    :laughing:
  17. Sep 14, 2012 at 7:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Where the fuck you been munchkin? :D
  18. Sep 14, 2012 at 7:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea man im still interested in that.
    i need to start making money tho before i can buy it ha
  19. Sep 14, 2012 at 8:52 PM
    BradyT88
    Bleh... My Grandpa is in the hospital and it looks grim... He went to the hospital in Malad yesterday to have some tests done and when he left the hospital he had a heart attack walking to his truck... They figure he layed there anywhere from 5-15 minutes before somebody found him and started performing cpr while an ambulance came around to him. Luckily his heart was still beating, but it stopped when they got him into the hospital. They got it going again and life flighted him up here to Poky. The did a hypothermia treatment to try to save his brain while they worked to stabilize him and get his oxygen levels back up to normal.
    They warmed him back up a few hours ago, but there are very low signs of brain activity:( and the hospital staff said it doesn't look good... (his brain may have starved while he was laying in the parking lot...) They said it can take 2-3 days for brain function to return after the hypothermia treatment though so we have our fingers crossed. He is breathing on his own and his body is naturally fighting off the clots so those are good signs. When they poked his fingers and toes he showed very slight pain reactions and he coughed once so things may be starting to come back:D
  20. Sep 14, 2012 at 8:59 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My thoughts and prayers are with your Grandpa Man! What is his name?
