Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 7, 2012 at 10:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No go look at local shops before you order to see if they can do it cheaper then Wheelers
  2. Oct 7, 2012 at 10:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You still on the stock billies in back?
  3. Oct 7, 2012 at 10:23 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    Wheelers charges 200 bucks to put the OME fronts together, toytech charges 100. that's why I went with toytech over wheelers for my lift.
  4. Oct 7, 2012 at 10:25 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Texas is great now that I am out of the there. Got back to co earlier this week. Now it's time to work, and when I am not at real work, it's time to fab. Gonna try to get a bunch done this weekend and early next week on my days off.
  5. Oct 7, 2012 at 10:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    You have an AAL in your spring packs don't you? Do you know how much lift you have back there with an empty bed?
  6. Oct 7, 2012 at 10:59 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Probably more like 1-1.5" I bet
  7. Oct 7, 2012 at 11:05 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Mark is going to take off the KYBs I gave him in favor of some longer 5125s. Seems the KYBs are limiting droop on his setup.
    He asked me if I wanted the KYBs back but I told him no, to just toss them if he doesnt want them anymore. Now I'm wondering if you might be able to use them. They are not done, though they have seen a bit of abuse lately. :eek:
    They are 21.46" extended and 14.17" compressed so they require 1"-2.5" of lift.
  8. Oct 7, 2012 at 11:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I'm guessing you did not see this ^^^
    http://www.tacomaworld.com/forum/north-west/174613-idaho-eastern-wa-bs-thread-1336.html#post5801801
  9. Oct 7, 2012 at 11:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Would be better then his stock ones. Even wi the new front shocks..you rear will be bouncy
  10. Oct 7, 2012 at 11:54 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Pics incoming :)
  11. Oct 8, 2012 at 12:03 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    So Ben likes it stiff in his rear huh....
    :rofl:
  12. Oct 8, 2012 at 12:03 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It'll get bouncy with more wore out shocks
    Offffffff????
  13. Oct 8, 2012 at 12:04 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Just take off the rear shocks and you'll have infinite flex...
  14. Oct 8, 2012 at 12:05 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    HEY call me we can do the install.
  15. Oct 8, 2012 at 12:07 AM
    Digiratus
    Roaming the PNW
    The RedHead
    fixed
  16. Oct 8, 2012 at 12:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Actually mine road good with like 200lbs in the back when I had to get my 10" shocks.
    I bet now it wouldn't be bad at all.
  17. Oct 8, 2012 at 12:12 AM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Good. We can do it at your place if need be. i just need two weeks notice, I have 3 day weekends every weekend.
  18. Oct 8, 2012 at 12:13 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Ian, from Mark
  19. Oct 8, 2012 at 12:14 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I don't like it either haha ill change it when I'm on my computer again.
  20. Oct 8, 2012 at 12:16 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    So this weekend was ThanksGive'R Weekend for us here in Nelson. Everyone gets to come home for their Thanksgiving with family and friends. The bars get packed and the town goes nuts at night. It was one messy weekend.. So today we got our hungover asses out of bed and went riding. It was a gorgeous day so i had to snap some pics but i forgot my real camera but had a shitty backup one. Edited them btw
    HAPPY THANKSGIVE'R EH!!! :canada:
