Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 22, 2012 at 9:24 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    And that right there is y i caged my old toy. Fit? Shit ill make the trail bigger via the skinny pedal.
  2. Oct 22, 2012 at 9:38 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    shut it non believer, if there is a will there is a way
  3. Oct 22, 2012 at 9:44 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Our frames flex way to easily. Its a good idea to get it boxed
  4. Oct 22, 2012 at 12:25 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
  5. Oct 22, 2012 at 12:25 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
  6. Oct 22, 2012 at 12:41 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    ^^^^-----he'll find a way to make it slow.
  7. Oct 22, 2012 at 12:41 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    No, our frames arent boxed in the bed. I think its boxed up to where it arches up to the gas fill.
    Trail Gear sells a frame box kit
    http://trail-gear.ca/default.cfm?fa=products&prodcategoryid=197
    "1995-2004 Tacomas have c-channel frames that are notorious for bending and cracking. The c-channel frame also contributes to axle wrap and wheel hop at the rear axle. Trail-Gears answer to this problem is to box in and reinforce the inside of the frame. Our Tacoma Rear Frame Box Kit comes with two plates that will completely box in the frame, and two pieces of DOM tubing. One tube is used for reinforcement and the other tube is used as an upper shock mount. The upper shock mount tube comes with metal sleeves and all the necessary hardware.
    This kit will help you avoid costly frame repairs and give your frame more strength, fixing many of the issues a c-channel frame causes while offroading."
  8. Oct 22, 2012 at 1:15 PM
    BradyT88
    BradyT88 Well-Known Member
    2nd gens are hardly boxed at all...
  9. Oct 22, 2012 at 1:23 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I read rear end.. :notsure: But its a good idea to get it boxed. You dont really want frame flexing. My frame is bent a little. I think i measured 1/2"-1" difference from the ground where the rear bumper bolts on:eek:
  10. Oct 22, 2012 at 1:24 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I heard they are worse than 1st gens for that. Early toyota trucks are almost boxed the whole way
  11. Oct 22, 2012 at 1:27 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    1st gens are always superior :cool:
  12. Oct 22, 2012 at 1:29 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Hey Ben, You think my Toyota emblem would fit your grill?
  13. Oct 22, 2012 at 1:31 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  14. Oct 22, 2012 at 2:12 PM
    BradyT88
    I'm pretty confident that 2nd gens take the power category:D and that extra power didn't hurt fuel economy any either:p
  15. Oct 22, 2012 at 3:06 PM
    rctoy
    konstantenos
    Pocatello Idaho
    I said it was caged there for the skinny pedal just makes it more of a show.
    thank GOD for believers
    94 and earlier where boxed all the way back till the bumper mount then the first gens where boxed to the rear axle forward spring hanger and the second gens i don't care to look into.
    But as far as frame boxing goes just order CBI's frame plate kit im running it and i hate trail gear those guys suck/ they are the walmart of toyota 4X4
  16. Oct 22, 2012 at 5:54 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    something about plastic bed sides....
  17. Oct 22, 2012 at 5:58 PM
    mh.meier
    The Doctor
    Commiefornia
    Dont mock my plastic bedsides! Soon to be glass! Also, something weird happened today. I posted in my own state's BS Thread........What is happening to me?!?!? Does this mean I have so much BS in me I have to dump it out into multiple threads? Tie to invade the MT thread as well.....
  18. Oct 22, 2012 at 5:59 PM
    MTgirl
    Weesa
    :quickdraw: watch your step boy!
  19. Oct 22, 2012 at 6:06 PM
    mh.meier
    The Doctor
    Commiefornia
    Haha, I am a good BSer. Everytime you mention the thread I stalk it a little, just to see whats going on. One of my best friends in the Corps was from MT and we hav a picture of us holding a MT flag in Afghanistan.
  20. Oct 22, 2012 at 6:08 PM
    BradyT88
    I dont quite think the bedsides are plastic, but they probably aren't as thick as yours. The bed itself is some sort of fiberglass material though. And besides I still outweigh you, plus I'm bigger so I might also likely have more air drag. And you still haven't raced my car! Haha. What kind of fuel mileage do you get with that 4 banger anyway?
