Idaho BS thread in the PNW
Discussion in 'North West' started by Jensonbt, Aug 28, 2011.
  1. Oct 30, 2012 at 10:23 PM
    The Raisin
    The Raisin Well-Known Member
    Mark
    Spanaway, WA
    streetqueen
    Badlands front bumper with a Smittybilt 8K winch, synthetic winch line. Demello sliders and bedbar. Custom rear bumper. Custom skid plates. Flex-a-lite tranny cooler with fan mounted in bed. Bilstein 5100's with SAW coils, AllPro UCAs, NW offroad rear springs (garbage), 4.88s and front and rear lockrights. Lots of custom sheetmetal work.
    I run my 33x12.50s at 10 PSI for wheeling and drop down to about 15 PSI for logging roads. Over the weekend I dropped them to 8 for some snow I was in. I have never had a problem with beads. I actually had to drive home on the highway about 150 miles at that pressure, the local gas station was not open yet on my way home so I just kept driving. I actually like the ride and feel of my tires at highway speeds with low pressure. And yes Mike I did check my gauge with two others I have and it reads about 6PSI higher so I adjusted accordingly.
  2. Oct 30, 2012 at 10:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Does that mean my cheapo vatozone gauge is sort of correct? It always read about 5 or 6 higher than your ARB gauge.
  3. Oct 30, 2012 at 10:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I was referring to your comment about how wide your track is. Not how narrow your tires are.
    :D
  4. Oct 30, 2012 at 10:42 PM
    The Raisin
    Mark
    Spanaway, WA
    streetqueen
    I guess so. that gauge I keep in the truck is not an ARB gauge. Its just a cheapo from Schucks or some place. I wont own anything if its made by ARB.
  5. Oct 30, 2012 at 10:48 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Sorry, thought it was an arb. It's red. :rolleyes:
  6. Oct 30, 2012 at 11:51 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    uuhh ya, you cant even tell its lowered. They needed a dumped truck to even it out. Lowered truck in the rotation? How about a truck with 4x4 suspension thats been lowered 2", good enough....
  7. Oct 30, 2012 at 11:53 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  8. Oct 30, 2012 at 11:58 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    can't tell, irrelevant.
    for wat?
  9. Oct 31, 2012 at 12:02 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    slammed bro!
  10. Oct 31, 2012 at 12:06 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    dam straight!
    gtfo
  11. Oct 31, 2012 at 12:11 AM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Talks shoot bout spacers, gets them.
    Brags how great they are, replaces them.
    Loves skinny tires,.....soon.
    Jk Ben lol
  12. Oct 31, 2012 at 12:19 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl: its inevitable
  13. Oct 31, 2012 at 6:48 AM
    BradyT88
    BradyT88 Well-Known Member
  14. Oct 31, 2012 at 6:49 AM
    C2T
    C2T Well-Known Member
    Richard
    Helena Montana
    Yes...it's a JEEP!
    35" Tires, AEV front recovery bumper, 2.5" AEV lift, Certified Mall Crawler sticker, Warn 9500 winch, Hi-Lift, Air compressor.
    Yup...I missed em.
    Curb weight is about 4130 so I start at about 1000lbs more than Lisa's rig. And I have added at least 700 or so to that I would guess.
    As for staying on top of the snow...there are some real technique to it. Tire width does make a difference as does the type of snow but I have been driving along, jumped out of my rig and sank chest deep in snow I did not know was that deep under me. There are times none of us go well and times when the snow is just right and we run over it like we are on tracks. But learning how to do that is a important if you run around these hills in winter. It has saved my bacon a few times now.
  15. Oct 31, 2012 at 8:13 AM
    BradyT88
    So you are almost as heavy as I am then so I may not be so bad off.
  16. Oct 31, 2012 at 11:01 AM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    hey there's nothing wrong with a little girth. besides the wife likes it.
  17. Oct 31, 2012 at 6:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    pfffff..wide tires are the shit :cool: floatyness is epic :D i love not being able to feel bumps :)
    More like anorexic tire fan boy..:laugh:
    Yea i have just not had time..and forgot my ipad at the gym :eek:(don't worry yes i have 2 COMPUTERS..just was never in my room)
    Nah man. I was in the gym on Monday..and tuseday..and this morning..and tonight. Pushing hard :cool:
    Yea i wheel at 12psi usually if im just wheeling. Its a great median i think. I have never gone lower then 10..haven't had to yet. Don't get deep enough snow here :rolleyes:
    dude..go to his build. Its impressive and a very clean truck. I wish i could turbo mine like his.
  18. Oct 31, 2012 at 7:29 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    :confused:
  19. Oct 31, 2012 at 7:31 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Oct 31, 2012 at 7:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If your renaming shit. Pm Chris. Way more active and is fast to respond.
