Idea on HID retro-fit 05+ tacoma
Discussion in 'Lighting' started by LEDCREATIONS, May 20, 2010.
Do you like it?
Poll closed Jun 19, 2010.
  1. Yes
    29 vote(s)
    69.0%
  2. No
    5 vote(s)
    11.9%
  3. Maybe
    8 vote(s)
    19.0%
  1. May 20, 2010 at 9:26 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Already done:
    http://www.xr-underground.com/forum/showthread.php?t=36773
  2. May 20, 2010 at 9:32 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Beautiful... Well when I finally get around to my retro, I will install the LED strip to at least just see what it will look like. $60 I figure why not see. No Halos for this guy though...
  3. Jun 3, 2010 at 1:01 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
  4. Jun 4, 2010 at 12:15 AM
    LEDCREATIONS
    LEDCREATIONS [OP] Member
    phoenix
    06 Tacoma TRD Sport
    I ended up not doing the LEDs. I did black out everything though. I used smoke tinting on the turns and reflectors. Came out pretty good. Still working on aiming the headlights(which is a bitch) I think my driver side got knocked after aligning and expoy because there is a slight angle to it :( other then that it is prrrreeeetttty swwweet
  5. Jun 4, 2010 at 1:03 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    thank goodness...!! aiming is all in the prep! get straight drilled holes and mount along the reference lines built into the reflector and your good to go! i did not have to adjust a thing on the last three retros i did because i did my prep right! mounted to ensure the cutoffs were level w/ eachother (which they were!) and jb welded up, no adjustments! if they moved after you epoxied them, you didnt mount them well enough...just imagine when you go over a speed bump or something...ensure they are mounted better before you finish them up :thumbsup:
  6. Jun 4, 2010 at 6:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    go with 8. 5 looks like a one winged duck going in circles :p
  7. Jun 4, 2010 at 11:30 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    too late....:D
  8. Jun 5, 2010 at 11:37 PM
    LEDCREATIONS
    phoenix
    06 Tacoma TRD Sport
    I think its all a alignment thing with just aiming them now. it looked a lil off because it wasn't sitting right in on the truck after I looked harder.
    Thanks yoshi for the help btw. Matt helped out too. He stated that they don't even use the 4 mounting screws and that they just jb weld the projector in. A tab did break off as I was installing the mounting screws but it worked out fine.
    I blacked out the reflector and the turns with automotive grade transparent paint(auto paint shop) same with the blacked out lights. Overall it was an experience and I'd do it again if the car didn't come stock with it :)
