Ideal coolant ratio?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MalinoisDad, Mar 14, 2019.
  1. Apr 16, 2019 at 5:03 PM
    #41
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    If you run Green (I do... in my opinion it's better than the red garbage) YOU HAVE TO FULLY FLUSH THE RED OUT BEFORE YOU PUT THE GREEN IN.
    greengaint97 likes this.
  2. Jun 18, 2019 at 1:52 PM
    #42
    dj5hall
    dj5hall New Member
    DJ
    2004 Tacoma, SR5 ext cab 2x4, 2.4l
    I think this thread has ended . . . but, just thought I'd mention a real life case for changing the rad cap. I had a motorcycle that was not leaking radiator fluid, but would overheat under extreme conditions. Extreme in this case being high speed cornering while going up mountain roads. After much work, research and frustration, it turned out to be the rad cap. It wasn't leaking fluid, but was not properly pressuring the system and was allowing air to enter. The air ended up in the water pump, causing cavitation (the pump impeller spins in air and does not move fluid). Replacing the rad cap fixed the issue. So, last weekend I replaced the radiator in my Tacoma and also replaced the rad cap, just to be safe. It's cheap insurance and should be done every few years.
    Breakfast Taco and Good deal like this.
