Ideal Tire Load Range
Discussion in '2nd Gen. Tacomas (2005-2015)' started by utacomah, Jun 17, 2020.
  1. Jun 18, 2020 at 1:06 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Yeah the notion the c-load tires is for commuter trucks is just not true.
    They exceed both the payload capacity and the tow hall capacity. Just FYI OP.
    Also, if you get stuck and really need to drop the tire pressure to tank track your way out, you'll hit a point of diminishing returns with E-load because the sidewall is so stiff. So unless you're kitted out with armor and at the pay load max, you won't have as much contact.
    utacomah[OP] likes this.
  2. Jun 18, 2020 at 1:15 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    This.
    I’m running E-rated 295/75R16 BFG KO2’s, no armor, no weight in the bed other than my full-size spare. Tire pressure plays a big factor. When I get work done at a shop, they tend to set it to 35 psi. It’s pretty harsh and you can see the contact patch on the tires where it actually rolls. Very noticeable bump steer too. I air it down just to 32 psi and it’s an obvious difference. Tires contact the road evenly, less bump steer, softer on bumps. Yes it’ll be slightly sluggish but I’m also re-geared to 4.56
  3. Jun 18, 2020 at 1:19 PM
    m603holden
    Marteeen
    New England
    Less acceleration, more rotating mass, worse mph, worse ride....
    Duckinatruck and stickyTaco like this.
  4. Jun 18, 2020 at 1:29 PM
    Island Cruiser
    Kauai
    Baja
    You’re quoting where he clarifies “...if you do any driving off road or on rough gravel forest service roads.”
  5. Jun 18, 2020 at 1:31 PM
    m603holden
    Marteeen
    New England
    100%
  6. Jun 18, 2020 at 1:36 PM
    Island Cruiser
    Kauai
    Baja
    You’re not wrong though. I wish they made a C load for my size in the KO2’s, I’d be all over it. E load works but you gotta make it work to be comfortable as a daily, like mine lol
    m603holden[QUOTED] likes this.
  7. Jun 18, 2020 at 1:39 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    This. In addition to the performance and handling impact of the additional unsprung weight it is also more wear on the suspension and drivetrain. That's a non-issue for some but it played a pretty big role in my choice to stick with a lighter wheel/tire combo.
  8. Jun 18, 2020 at 1:44 PM
    m603holden
    Marteeen
    New England
    Basically if someone needs to ask about E load tires, they don't need E load tires. 95% of folks don't need E load tires. It's a bro factor. In cases such as the game warden, he knew he was shredding tires in the terrain he traveled regularly in. That's a good reason to move up to E load.
    Not shredding any tires and saying "well they're tougher!" is a bad one.
    I'll never tell anyone how to spend their money. But I'll call it as it is, and as I've personally done.
    Tire selection can be tricky. Helps a lot if you can get into a 17" rim over 16". Duratracs, Terragraplers, wild peaks, all great tires in a tire a stock truck can use with a c load rating.
    Sig45 likes this.
  9. Jun 18, 2020 at 1:46 PM
    m603holden
    Marteeen
    New England
    Yup. Suspension and traction alone. Valving is based off velocity. If the tire doesn't flex its instant high velocity on even the smallest feature, ultimately taking away from handling.
    I'll be going to 34s here shortly and I'll still be sticking with C load.
  10. Jun 18, 2020 at 1:50 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Just to add - I average about 2-3K miles each year on forest/logging roads of varying quality (from 50 mph smooth gravel to 5 mph kidney bruising secondary roads to shale nightmares) up in northern Maine (May & June for fishing and Oct-Nov for hunting).
    ethandoubleu and m603holden like this.
  11. Jun 18, 2020 at 1:52 PM
    m603holden
    Marteeen
    New England
    I mean if the C-load is good enough for the Golden Road.....
    Fwiw, I think Greenville road might be a bit worse off. I've hit that thing doing 65and anything under that my suspension was just hammering. Above It, pond skimming pure butter. I love that hill coming from Moosehead to GR.
    Sig45[QUOTED] likes this.
  12. Jun 18, 2020 at 1:55 PM
    Sig45
    Mark
    Maine
    Love that area....been going up there since 1984 when I was a wee young lad. Was just up around the Musquacook Lake chain (quite a bit further north) not too long ago. I'm never concerned that I'm running C's.
  13. Jun 18, 2020 at 1:57 PM
    Sig45
    Mark
    Maine
    These Taco's get quite squirrelly pond skimming....lift dirt drifting. :thumbsup: :D
  14. Jun 18, 2020 at 1:58 PM
    m603holden
    Marteeen
    New England
    Hammer hangers.... I'll tell you bud.
    Also edit, I was off with the nittos. Those come in xl, near c load. And the wild peaks don't come in c load anymore. But the cooper's do In both 16/17. Illl get a list for OP
    utacomah[OP] and Sig45[QUOTED] like this.
  15. Jun 18, 2020 at 2:00 PM
    #35
    Sig45
    Mark
    Maine
    Never considered them.
  16. Jun 18, 2020 at 2:00 PM
    #36
    Island Cruiser
    Kauai
    Baja
    What 34” tires you going with that’s C load?
  17. Jun 18, 2020 at 2:02 PM
    #37
    Island Cruiser
    Kauai
    Baja
    I have yet to get mine mounted lol
  18. Jun 18, 2020 at 2:04 PM
    #38
    big sky
    big sky Well-Known Member
    Montana
    2012 TRD Sport DCSB 4x4
    I'm on stock rims, no spacers w/ 265/70r17's- no rubbing whatsoever, anytime
  19. Jun 18, 2020 at 2:05 PM
    #39
    m603holden
    Marteeen
    New England
    @utacomah
    Goodyear duratracs
    Cooper At3 LT
    BfG ko2
    Some good c-load right off the bat if you're looking for a 16' or 17" rim
  20. Jun 18, 2020 at 2:07 PM
    #40
    Sig45
    Mark
    Maine
    And Toyo Open Country AT2 - 16"
