Ideas for a tailgate protector?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Nov 13, 2010.
  1. Nov 13, 2010 at 6:19 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I am always hauling stuff - ladders, wood, pipe, etc. - that rests on top of my tailgate. It's getting scraped too much and I am thinking about some type of rubber or padded strip that I can easily put on and remove to protect it. Something like a section of foam pipe insulation with the slit down the center but I don't think they are big enough. Has anyone done anything like this? I would be interested in ideas....right now I am just throwing a rubber pad over it but it is really a jury rig. Thanks
  2. Nov 13, 2010 at 6:24 AM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    I've wondered about the possibility of doing something like a steel plate to replace the plastic on the inside of the tailgate. Powdercoat it black, and make it shaped so that it covered the top edge, and maybe roll over a little to the painted side. That way things would be protected, and if you needed to put a lot of weight on the tailgate it would be reinforced.
  3. Nov 13, 2010 at 6:33 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    That's a good idea and they sell metal plate tailgate cap protectors like this. However, I prefer a rubber removable fix......giving the tailgate top better reinforcement is a great idea though.....
  4. Nov 13, 2010 at 7:00 AM
    xodeuce
    Alabama
    2004 UZJ100
    Yeah I've seen a lot of work trucks that have carried heavy stuff and bent the tailgate on the top. Always makes me cautious about having stuff in there like that. Not to mention, the more weight is past the tailgate, the more force is on it. Just makes whatever is propped up transfer the force like a big lever.
  5. Nov 13, 2010 at 7:06 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Hmmmm....wonder if we could get one of these bright, young, metal fabricating vendors to come up with something that is soft (rubber or something close) on the inside and outside, is removable, and sits over the top of the tailgate?
  6. Nov 13, 2010 at 7:10 AM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    If I'm not mistaken doesn't Chevy have one of these things for their silverado models. You could use that for a template....
  7. Nov 14, 2010 at 1:34 PM
    reg boulette
    reg boulette Well-Known Member
    Somebody did post a layout drawing for a 'diamond' aluminum sheet tail gate covering some time ago here or on TN. For the life of me, can't find proper search terms to bring it up. It had all necessary measurements though.
  8. Nov 14, 2010 at 3:13 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Probably easier to just buy an aftermarket one and cut it to fit. I'm still looking for a heavy rubber one though.....
  9. Nov 15, 2010 at 11:24 AM
    reg boulette
  10. May 16, 2014 at 6:39 AM
    ramblinruss
    ramblinruss New Member
    Russ
    NC
    Prerunner SR5 TRD
    I need a tailgate protector for mine as well. I have searched for an aftermarket one, and there are several that claim to fit. You can get a diamond plated steel one or a vinyl one from various web sites. Just google "tailgate protector" and a lot of web sites will come up. I have found one vinyl one at this site: http://www.partsgeek.com/catalog/20..._mechanical_-ar-_trim/tailgate_protector.html
    for $72, but they want to charge $130 for shipping!!! Now this is basically a piece of plastic about 5' long and weighs maybe 2 pounds. I've heard of expensive shipping, but these guys have fallen off the deep end!! Anyway, I'm still looking if anybody else might know where to check. If all else fails, I'll go to a dealer and get one, but usually aftermarket is about 1/2 the price of dealer price.
  11. May 16, 2014 at 3:47 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I haven't followed the for sale thread for awhile but the guy at G Tek seemed to make a real quality door sill protector and it seems like there was mention of him checking into making protection for tailgates. You may want to shoot him a PM, if he doesn't have one now maybe he will if demand is high, never hurts to ask. If you haven't read his thread search G Tec.
  12. May 16, 2014 at 6:54 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    You might check out Relentless Fabrication.com . Hes a vendor on here. Makes tailgate protectors...as well as several other items. I got one on order for my 2011.
  13. May 17, 2014 at 6:20 AM
    ramblinruss
    Russ
    NC
    Prerunner SR5 TRD
    Found the spot!! Took a lot of searching, but there is a place called Rockauto.com. They had the exact match that I needed and called it a weather strip instead of tailgate protector or cap. From what I could see, it looks like they have pretty much anything you need.
