Ideas for filling shell and tailgate gaps?
Discussion in 'Tonneau Covers, Caps and Shells' started by yodiggity42, Aug 14, 2022.
  1. Aug 14, 2022 at 8:01 AM
    yodiggity42
    yodiggity42 [OP] Active Member
    I picked up a camper shell recently (check it out). I'm trying to rainproof it. It passes the garden hose test all around except in the back near the tailgate, and the tailgate itself has some gaps (see pic below).
    Do y'all have any ideas for filling these gaps? The only thing I can think of is some adhesive weather-stripping, but I thought the friction from opening/closing the gate would rub that off pretty quick.
  2. Aug 14, 2022 at 8:08 AM
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    Maybe one of those weather stripping bars that go on the bottom of a door . Attached to the bed , I think it would hold up.Home depot has an assortment of sizes....
  3. Aug 14, 2022 at 9:28 AM
    yodiggity42
  4. Aug 14, 2022 at 9:59 AM
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    same issue with me.
    pita.
  5. Aug 14, 2022 at 10:05 AM
    yodiggity42
    Pita might work. Although it could get a bit soggy in the rain, and I'm trying to watch my carbs.
    surfjones likes this.
  6. Aug 14, 2022 at 10:21 AM
    bush rat
    BC
    2022 6MT Access Cab
  7. Aug 14, 2022 at 10:33 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Looks like you have a 1st gen. I'd use this one around the tailgate like I had on my 2003. Mounted to the bed (not the tailgate) in a widened U shape.
    https://www.amazon.com/Ultimate-Tailgate-Seal-Taper-10ft/dp/B00IPQWXZQ/
    It's a bit hard to see, but this is the best photo I still have of the truck. You can see that across the bottom of the bed, the seal needs to sit a bit lower as when you close the tailgate it pushes it down.
  8. Aug 14, 2022 at 10:33 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  9. Aug 14, 2022 at 11:27 AM
    yodiggity42
    Thanks for the recommendation! That looks perfect.
  10. Aug 14, 2022 at 3:50 PM
    bush rat
    BC
    2022 6MT Access Cab
    to quote a different post:
    “ dad jokes next aisle”
