Ideas for heating a Condo in New England
Discussion in 'Garage / Workshop' started by Xtremsiege2, Dec 9, 2021.
  1. Dec 9, 2021 at 9:15 AM
    Xtremsiege2
    Xtremsiege2 [OP] Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    So after selling my condo in August i figured renting would be great; don't have to fix a thing nor am I liable for much, pay my rent and utility bills and have one less worry in the back of my mind.
    Come to find out there is a Freon leak in the AC line, wasn't too concerned - i don't need AC generally..however i did not consider the leak means the heat-pump produces no HEAT, in Connecticut. Spoke with Landlord and she told me she would send over an HVAC contractor, he comes and refills and leaves...still little to no heat. Now that its been getting into the low 30s i emailed her to get the ball rolling on this again, find out this morning she had an estimate to fix and the HOA board rejected it, so I'm kind of stuck with this for now. What are some decent heating options out there?
    Specs-unit is about 1000 sqft with 2 bedrooms and 1 bath and a lower end unit meaning its colder than the ones wedged in between.(I have 2 space heaters currently which work fine, and have a nice portable gas fireplace but the bioethanol is a fortune and burns fast)
    Thanks for any ideas I can leave turned low while I'm @ work for 12 hours a day.
  2. Dec 9, 2021 at 9:22 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Xtremsiege2[OP] and boston23 like this.
  3. Dec 9, 2021 at 9:24 AM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
  4. Dec 9, 2021 at 9:29 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I wouldn't recommend that for heating a home. Not enough output plus you'll be going through those small propane tanks like crazy since they only last a few hours per tank.
  5. Dec 9, 2021 at 9:31 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Electric radiator
    Xtremsiege2[OP] likes this.
  6. Dec 9, 2021 at 9:43 AM
    Xtremsiege2
    Norwalk CT
    Thanks this might just fit the bill...
    And i was shocked, landlord either lying or because the decks were recently replaced and the line goes under the deck.
    About this item
    Rated To Heat up to 1000 Square-Feet with Auto Energy Saving Model With High and Low Feature. Tip-over protection and Overheat protection
    Dual Heating Systems featuring infrared quartz tube Plus PTC with 12hr automatic shut-off timer
    IR Remote Control, High Pressure Low Noise Blower with Noise level 39 dB super quiet
    Electronic Thermostat: range 50 to 86 degrees. Caster Wheels and lifetime filter
    Weights: 25 pounds and uses 12.5 Amps of Power. 1500 Watts
    Was looking into these as well. The electric heat can get pricey but its better than none..thanks.
  7. Dec 9, 2021 at 9:45 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    electric oil heater. We have one in the house. they generate a good amount of heat for what its worth
  8. Dec 9, 2021 at 10:23 AM
    tirediron
    Hard cheese for the landlord! I would think there's some sort of tenancy rights legislation in your state; I'm sure it includes primary heat as a basic entitlement of a leased residential property...
  9. Dec 9, 2021 at 10:36 AM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
  10. Dec 9, 2021 at 10:47 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How is your condo heat paid? Is it in the lease, or are you responsible for utilities. I think the landlord is responsible for something.
  11. Dec 9, 2021 at 10:47 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I'd pressure the landlord more. The HOA thing sounds like a BS excuse for them to not spend abunch of money. I don't know how an HOA can deny repairing your heat.
    auskip07 and boston23 like this.
  12. Dec 9, 2021 at 10:57 AM
    auskip07
    Skip
    Atlanta, Ga
    this is why i like to own my stuff.... if it needs to be fixed ill fix it or get someone to fix it. Landlord doesnt care because she isnt living there.
  13. Dec 9, 2021 at 12:33 PM
    Xtremsiege2
    Norwalk CT
    Thanks, shes trying i really don't want to go this route.
    Heat is generated through electric paid by tenant-me. Its a heat pump each unit has individual heating/cooling.
    I know the president when i moved in, i'm going to ask her about it and can see if the Landlord is lying. Honestly my landlord is in her 70s and doesn't need the money thing, shes not a slumlord. Had an amazing deal, well until this.
    Its great until the rainy day fund needs to be used and then find out X caused Y to fail and you should probably replace Z while you're at it. In the market up here its a sellers and took advantage otherwise i'd be doing my own shyte.
