Ideas for locking a Dometic CFX into bed?
Discussion in 'General Tacoma Talk' started by custmpaint16, Jan 28, 2024.
  1. Jan 28, 2024 at 7:57 PM
    custmpaint16
    custmpaint16 [OP] Active Member
    Phoenix
    Wanting to lock the fridge into the bed when we leave it at trailheads. Only solution I've been able to come up with is to make a steel padlock bracket mounted to the side handle bolts, which would get blocked when there's a pad lock and cable attached.
    Anyone have a better solution?
  2. Feb 1, 2024 at 2:22 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Are you just keeping honest people honest ?
    Is the fridge only in the truck when it will be needed ?? So it gets removed every week or so?
    I made many secure locations for storing weapons in vehicles over the years.
  3. Feb 1, 2024 at 2:46 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Replace the hex screws for the handles with security torx, and run a thick cable through both handles to something secure.
    custmpaint16[OP] likes this.
  4. Feb 1, 2024 at 6:23 PM
    custmpaint16
    Phoenix
    It gets removed after each trip, its just to keep people honest when we are at trailheads or in town at a random night in a hotel if we are on a long trip...
  5. Feb 1, 2024 at 6:24 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    mine is locked to the bedrack with a steel metal tie and lock.
  6. Feb 1, 2024 at 6:48 PM
    TacoTuesday1
    FL
    used a bike lock to seat bracket when I had mine in the cab.
    might work in the bed.
    I’d be surprised if there’s no aftermarket solutions.
    that’s not including the potential for a locking camper and tailgate lock
  7. Feb 2, 2024 at 4:47 AM
    custmpaint16
    Phoenix
    do you loop that through the dometic handle? If so, did you do anything to replace the hardware so it can’t be unscrewed?
    thx
  8. Feb 2, 2024 at 5:45 AM
    Bivouac
    If you don`t change the hardware it kinda defeats the whole purpose.
    You want to make stealing it has difficult as possible. Any way to disguise what it is putting it in something else.
    This is under some sort of cover not exposed to the elements .
    Good luck!
  9. Feb 2, 2024 at 6:35 AM
    ramonortiz55
    Ramon
    Texas
    stock
    yes and no.
    its easier and faster to cut the cable or lock than unscrewing the handle.
    if they unscrew the handle vs cutting the bolt they deserve it.
  10. Feb 2, 2024 at 1:21 PM
    TacoTuesday1
    FL
    where do you have it
    If it’s in an open bed probably not a good idea to have it exposed to elements like sun heat to work hard against and water.
    if it’s regular bolts you can probably replace with tamper proof and keep a key for that. Maybe even two bike locks.
    hopefully insurance would cover in the event of loss.
