Ideas for new contruction
Discussion in 'Garage / Workshop' started by Joe D, Dec 11, 2013.
  1. Dec 13, 2013 at 3:27 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    In the same boat. I designed a wood room that holds ten cords of wood under the front porch of the house. I am also am going a couple extra courses on the masonry, to accommodate for ductwork. My house has a basement though and I know a lot of houses down south are just on a slab. Start thinking about your heating and cooling options, that's what I have been doing recently. Good luck with it, sounds like you are on the right path.
  2. Dec 13, 2013 at 3:41 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Does your area have termite / carpenter ant issues ?
  3. Dec 13, 2013 at 4:20 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    If you're wanting wood heat, I like the water stove boilers like the all stainless steel Hardy brand and add some solar panels on the garage or shop so you can have plenty of hot water, and all you're fire wood can be kept away from the house and near the outdoor heater. I like the copper pipe also, but with well water, have it tested you may need a water softer to adjust the Ph and hardness of the water but town or county water should be fine.
  4. Dec 13, 2013 at 6:09 PM
    Frkypunk
    Timmy
    Woods of P.A.
    No issues...and it will be well ventilated...thank you for the concern though:)
  5. Dec 13, 2013 at 6:11 PM
    OZ-T
    Peter North
    British Columbia
    I'm not concerned , just hate introducing bugs into a new home
  6. Dec 13, 2013 at 6:14 PM
    Frkypunk
    Timmy
    Woods of P.A.
    I agree, but it will be all block with corrugated metal roof(for the porch) there are always bug problems and air problems I think I may have solved that.
  7. Dec 13, 2013 at 6:23 PM
    BamaToy1997
    Bill
    Navarre, FL
    I gotta agree BIG time on that one!
  8. Dec 13, 2013 at 6:40 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    I would want a bathroom to every bedroom.Enough room in the kitchen for a kegerator.Underground shooting range in the basement.I think big.
  9. Dec 16, 2013 at 3:32 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
  10. Dec 16, 2013 at 4:29 PM
    Joe D
    Joe D [OP] .
    I like all the things listed so far EXCEPT the squatty potty. That's NOT gonna happen. :). Though I do think a urinal is a cool plan.
    My last place had most of the stuff listed above. I didn't have the break between the brick & framed walls but, it does sound pretty reasonable.
  11. Dec 16, 2013 at 4:32 PM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    An outdoor shower.
  12. Dec 16, 2013 at 6:34 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    At least 3 exterior hose bibs; all exterior doors at least 3' wide; 3'6" wide stairs at minimum; 9' first floor ceiling; stick frame roof ( no trusses!) and install plywood on attic floor; minimum of 5 exterior outlets; on demand water heater; for private septic- two septic tanks and oversize drain field;
    Interior doors 2'10" minimum width; 3'6" minimum width hallways; each room should have a home run for wiring; install plumbing in basement floor for future finish.
    I also put a washbox in my family room at aquarium location.
    This is added to the 2x6 exterior walls and insulation previously mentioned by prior posts.
  13. Dec 16, 2013 at 6:43 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Big ass garage with a loft and truck lift. :D
  14. Dec 16, 2013 at 6:49 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    3 car garage, shop area (sound in the walls and ceiling throughout the whole house and garage, and shop),heated and cooled tiles in the kitchen, mudroom, and bathrooms.
    Sound system controlled by a central computer, which is controlled by smartphone if you want.
    Vault room, and a theatre room.
  15. Dec 21, 2013 at 6:55 PM
    #35
    MiniBike
    MiniBike Well-Known Member
    Concrete safe room w/plumbing if possible. False rear walls in bedroom closets for some additional hidey space. Full bath either in the garage or w/direct access from the garage. Walk in kitchen pantry.
    I used to decorate a lot for Christmas, so I added outlets around the entire perimeter of the house, outlets around the yard and carriage lights throughout the outside living areas - all wired to a timer in the garage. I'm never more than 50' from electricity.
  16. Dec 21, 2013 at 6:58 PM
    #36
    OZ-T
    Peter North
    British Columbia
    If you're going to have an attic why not trusses ?
    and what's your reasoning on the 2 septic tanks ?
  17. Dec 22, 2013 at 4:09 AM
    #37
    coffeesnob
    VA
    My guess on the septic tanks would be one for toilet waste and the other for grey water.
  18. Dec 22, 2013 at 4:59 AM
    #38
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    Have the garage/ shop detached from the house. It will be cheaper on the house insurance, ask them. And you will have more storage space space for a lift, man cave, office. Oh the ppossibilities. ....
  19. Dec 22, 2013 at 9:52 AM
    #39
    OZ-T
    Peter North
    British Columbia
    That's completely redundant if they both then go into the disposal field
  20. Dec 22, 2013 at 3:43 PM
    #40
    Frkypunk
    Timmy
    Woods of P.A.
    The tank should have both in it...it kind of acts like a giant toilet bowl...so what oz is saying is true, unless you have different codes there.
