ideas for replacing bad 6" trailmaster strut
Discussion in '1st Gen. Tacomas (1995-2004)' started by harleygirl1413, Jan 25, 2011.
  1. Jan 25, 2011 at 6:41 PM
    harleygirl1413
    harleygirl1413 [OP] Member
    vickie
    seattle, wa
    96 tacoma, v-6
    6" trailmaster lift, 33 x 12.50 Toyo mt
    replacing my blown out struts on my 96 taco with a 6" trailmaster lift. they have discontinued making the lift and parts. I have done some research on replacements but cannot seem to narrow down a part number for the struts. Im looking at gabriel or bilstein replacements. Anybody have those part numbers? also, are they direct replacements or are there any mods? had a response from a gentleman on this site stating that the gabriel struts were short and needed spacers. his idea was to invert them to make them fit, is this a good idea? will they work properly if so? [​IMG]
  2. Jan 25, 2011 at 7:23 PM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    If you want me to not answer in your threads just post up or send me a Pm... I understand that you want the opinion of others and that is cool... But in my search I have found no one else in suppor of this lift.
    Not invert the strut...
    Invert (FLIP) the top mount as to make up for 1/2 the difference in strut legnth (VW to TM).
    The strut mount IS: (3 studs and nuts with a rubber bushing in the middle that the strut shaft goes thru with a nut on the top of the shaft) It attaches teh top of teh strut shaft to the upper Trail Master bracket. You can't see this part on your truck because it is directly under the inner fender (In the wheel well. I can take pictures of it beacuse I have the front clip off of my truck.
    Strut mount pic:
    TO do the inverstion mod you knock the studs out flip the mount and reinstall it upside down with bolts and spacers.
    Your Strut part numbers are:
    85-91 golf/jett1 ~ part numbers that still work as of '07
    Bilstein HD W0133 1605589
    gabriel G44714
    monroe 81853
    napa 72873
    If you measure your original struts you can go to the catalogue and see for your self what struts will fit. Their are a few Toyota offerings that look like good canidates (Starlet Supra Celica MR-2) but replacment Cartridges for those modles are not as popular as standard struts and are much harder to locate. I have not found a supplier for them yet.
    FYI ~ Each time folks mention this lift other folks jump in to kick them in the teeth about how crappy it is. The only support i've found is from Rob ~ "WATRD" over on TTora. Everyone else generally says take off the TM 6" lift and throw it away. Go $2000 coil overs for 3" of lift or Go $5000 SAS.
    http://www.tacomaterritory.com/forum/showthread.php?t=17433
  3. Jan 25, 2011 at 7:47 PM
    Whitfield
    Central Virginia
  4. Jan 26, 2011 at 9:36 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Whit, that because that's the best thing to do is get rid of it.. I don't even know why TM stopped supplying the struts, maybe they knew their design sucked :( It's shitty when people get a truck with it, but hey, lessons learned. At least you're one person on here that can provide help and information to them. :thumbsup:
  5. Dec 11, 2011 at 7:24 PM
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
  6. Jan 3, 2017 at 1:46 PM
    Kodiakutah@12
    Kodiakutah@12 New Member
    2000 tacoma
    4inch lift
    I have a 2000 Tacoma with this lift one strut is leaking ,it's a 4 inch lift will this same technique work and with these struts ?
  7. Feb 23, 2019 at 8:47 AM
    Kstone1987
    Kstone1987 Well-Known Member
    Keith
    1996 Toyota Tacoma
    6 inch lift 33 in tires
    I have a 96 tacoma with a 6 in i belive trailmast kit on it both shock absorbers and mounts are bad im looking for replacement parts if someone could help I appreciate it .
  8. Feb 23, 2019 at 8:47 AM
    Kstone1987
    Keith
    1996 Toyota Tacoma
  9. Feb 23, 2019 at 8:48 AM
    Kstone1987
    Keith
    1996 Toyota Tacoma
  10. Apr 20, 2021 at 7:03 PM
    Mr.Clark
    Mr.Clark Member
    Kelly
    1999 Taco sr5 trd 4 by4 ext cab
    lift / air intake
    Could you put some kind of spacer on the second strut instead of this?
