Ideas for Rubber bedliner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilred, Nov 21, 2011.
  1. Nov 21, 2011 at 6:37 PM
    lilred
    lilred [OP] Member
    Lon
    St. Louis, MO
    4 cyl SR5 tacoma 4x4
    Any ideas for a good cheap rubber floor to put in my bedliner. Are there any spray on products to maybe make it non-sliding. Tired of stuff sliding around! Or just go buy one:confused:
  2. Nov 21, 2011 at 10:18 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    If you are looking for a cheap way out you can look on craigslist or go to the feed store and buy a "stall matt" They are rubber matts meant for the bottom of horse stalls. They can take anything you throw at them and you can find them for $20 apiece sometimes.
    I bought the Tacoma bed mat from the dealer, but haggled with the parts manager until they matched what I could get it for on-line. Bout 80 bucks I think. Good luck.
  3. Nov 22, 2011 at 4:05 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    A friend got a stall/horse mat .... cut it somewhat to fit. I have the OEM ... they wanted something like $118 ... got them down to $81 (go figure) ... for looks ... OEM ... both do the job well.
  4. Nov 22, 2011 at 5:27 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I went with the OEM mat. Threw it in and done. Hated things sliding around as well. Not that someone has not done it, but I have not seen anyone do a spray in yet. I guess if you scuff up the bottom of the bed and spray in a rubberized style of spray in bed liner and it adheres to the plastic it should work.
  5. Nov 22, 2011 at 5:43 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Big Lots has small ones in the auto section if you want cheap.
    I have seen mats @ tractor supply.
    JC Whitney sells cut to fit.
    CL using searchtempest per your zipcode may find OEM used in your area or another brand that you can cut.
    I got mine from dealer, he price matched an online price from another dealer.
    It was like $90.
    Used I have seen them for $50.
    I kept mine and use in the tundra it is very heavy & good quality.
  6. Nov 22, 2011 at 5:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Try JCWhitney as Simon's Mom mentioned or Auto Anything. I think I got a heavy rubber mat for $60 shipped. It you want something spray in, look at Rustoleum Bedliner although it's not rubberized, it is textured. There are rubberized spray in bedliners but you'll spend more on a good DIY kit than you will for a rubber bed mat.
  7. Nov 22, 2011 at 6:26 PM
    lilred
    lilred [OP] Member
    Lon
    St. Louis, MO
    Thanks all for the ideas!
  8. Nov 22, 2011 at 7:36 PM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
  9. Nov 22, 2011 at 9:37 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    As mentioned, I found one on Craigslist for $50. A little dirty, but I ran through the carwash on the way home from picking it up. It is really handy. I'm sure the stall mat way is a little cheaper, but I like the OEM look, and I like not having to cut stall mat to fit.
  10. Nov 22, 2011 at 11:38 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    There is no bed liner in the trucks the composite bed is the bed itself just saying....
  11. Nov 23, 2011 at 4:23 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Ya, I think OP got that ...... :cool:
  12. Nov 23, 2011 at 4:30 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Tractor Supply stall matting. Comes in 5 foot widths and sold by the foot, $5 a foot for the thicker stuff was $25 total for my short bed. Or you could get the thinner stuff for about $4 a foot if you want to save a little more. It's tough enough the thinner would probably work just as well.
    A little trimming around the wheel wells and it looks great. I hauled about 12 loads (6-8 tons total) of broken brick and concrete rubble this summer and no marks were left on the mat even though my son and I just tossed the stuff into the bed.
  13. Nov 23, 2011 at 5:33 AM
    johnnyman1
    johnnyman1 Well-Known Member
    Jax
    2012 TRD OR PRE
    nerf audio
    bought the OEM for $80. They wanted $110. It is really nice and I have no regrets. Perfect fit and very heavy duty. The others I looked at were not that much less expensive. Some wanted you to cut them down to size,, and i was not comfortable with that. If you can pony up the $80 I would go for it. If you actually have a working truck that will be used for hauling stuff alot then go with what buddywh1 said.
  14. Nov 23, 2011 at 9:58 AM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    Just take the plunge & get an OEM. No worries about cutting & fitting. I couldn't imagine not having mine.
  15. Nov 23, 2011 at 10:04 AM
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    OP, nice username lol...
  16. Nov 23, 2011 at 10:05 AM
    jjw1
    Jesse
  17. Nov 23, 2011 at 10:08 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    i got a can of the Rhino liner stuff and just coated the ridges in the bed. works like a champ. but that shits a little expensive if you dont have some just laying around. i just used a half used can that we used to rhino line the fuel tank on the boat i worked on. (so it was fo free)
  18. Nov 24, 2011 at 11:21 AM
    tpr676
    tpr676 Well-Known Member
  19. Nov 24, 2011 at 3:06 PM
    gap2000
    gap2000 Active Member
    Ken
    Evans Ga.
    2014 Reg. Cab 4x4
    Don't buy junk for your Toyota. Look at Bedrug.com you will be very happy with it.
  20. Nov 25, 2011 at 7:49 AM
    scotch
    Mark
    Centennial, CO
    Lots of Stuff
    Thanks! They are 17" 4runner sport rims with bfg all terrain tires.
