ideas needed -Rear window open while raining
Discussion in 'Tonneau Covers, Caps and Shells' started by DiscoYaker, May 15, 2021.
  1. May 15, 2021 at 4:37 PM
    DiscoYaker
    DiscoYaker [OP] Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    My older shell doesn't really drip or leak with my rear window door open while raining. I think partially because the 'U hinge' deally spans the whole length.
    My newer LEER hinge is short 5" or so on both ends. I want to be able to keep it open. Any ideas for some kind of gutter system? The water drips down the outer portion of the window, flows to the end of the hinge then drips in bed.
    Tarp will work but not for me. Who wants to stare at that during a nice drizzle?!
    I can prop window so that window has downard tilt but there is still a lot of drippage.
    Any ideas? Have I explained enough for you to understand what the hell I'm talking about?
    Fast1 likes this.
  2. May 16, 2021 at 7:53 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    seems I'll have the same problem with the new Leer double handle rear door also..
  3. May 16, 2021 at 8:23 PM
    DiscoYaker
    SE USA and Alaska
    Unfortunately yes you will. Other than this one small problem I've been very happy with mine the past year and a half. I have the duel t-handles as well
  4. May 16, 2021 at 8:25 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Is it practical to only open it partially, so the door tilts away from the shell rather than toward?
    Could also try to make use of capillary action and run a string across the top so water would follow the string down rather than drip in? Although in heavier rain that may prove impractical...
    https://youtu.be/wVtHot74ToI
  5. May 16, 2021 at 8:32 PM
    DiscoYaker
    SE USA and Alaska
    I like the string idea. 8ll give something like that a try sometime during a drizzle.
    I can prop it open partially but anything over 3-4" results in the same problem.
    I'm thinking about extending the hinge as much as possible if I can find the right material. I guess they cut it short (compared to older shells) to save a few pennies
  6. May 16, 2021 at 8:33 PM
    BudFriendguy
    Zak
    Seems soaking the string is important, so again not 100% practical, but it's cheap to try out.
  7. May 17, 2021 at 7:13 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I have the same issue with my ARE- water hits the window, runs down the window and soaks the end of the bed including anything that happens to be there like my sleeping bag and shoes. I looked into buying some of the flexible adhesive gutter/drip rail like they put on RVs but never got around to it. It would have to project beyond the edges of the window and I figured I'd need a piece on the shell as well.
