Ideas on how to secure 2x10 boards used in the bedliner as barriers
Discussion in '1st Gen. Tacomas (1995-2004)' started by ezatnova, Feb 20, 2011.
  1. Feb 20, 2011 at 6:20 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    11 DC TRD OR
    Hankook Dynapro 265/75/16, Icon Progressive AAL, 5100's @ 1.75, derped badges
    I have the Toyota bedliner in my 04 ext. cab. Rather than have crap slide all around in the bed, AND to allow me to carry full sheets of stuff if I ever need to, I got two 2x10 boards cut to the width of the bottom of the bedliner. I slid the boards into the to formed recessed areas and they worked great...for about 2 weeks. With some jostling around, the little bottom corners of the wood got rounded off and worn, and then the boards would just fall over in about 2 minutes of driving after re-setting them.
    The main problem is that the bad liner walls are not straight up and down. They go out like \____/ slightly. So, my boards that were cut straight, really only "grabbed" at the very bottom, if that makes sense. Last night, I spend a while cutting wedges to screw onto the end of my boards so that they will better follow the widening angle of the bedliner, as it goes up. It's definitely a more snug fit, but I'm worried that over time, the wood will wear again and I'll start having the same issue.
    I can't be the only one who likes having the separation in the bed and the full-sheet capability, so what is everyone else doing? I feel like there should be some kit available that securely lets you put the boards in the bedliner in a real way, rather than sort of rigged in there.
    Any thoughts?
  2. Feb 20, 2011 at 6:24 AM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    take measurements of the top and bottom width then do a little calc to determine the angle. get it cut right
  3. Feb 20, 2011 at 6:25 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i just use a bed bar. ..actually, i have 2 of them. ..they work great when i need to prevent random items from sliding around.
  4. Feb 20, 2011 at 6:28 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    11 DC TRD OR
    It's nearly impossible to get it cut for an exact fit. Hard to describe, but the bedliner notches "stop" about 7/10ths of the way up the side, then it starts to be just the normal liner pattern, which is little bumpy ridges.
  5. Feb 20, 2011 at 6:28 AM
    ezatnova
    ezatnova [OP] Artax
    West Chester, PA
    11 DC TRD OR
    That looks neat, but, would it punch through the bedliner? The liner isn't skin tight on the metal and I'd think it could crack right through.
  6. Feb 20, 2011 at 6:35 AM
    TTGuy711
    TTGuy711 Well-Known Member
    Jake
    Charlottesville
    17 AC TRD Sport
    I have mine pretty tight and it's fine. I just took it out yesterday to load some stuff up and there's no marks or anything. But it's adjustable so if you feel it's as tight of a fit as possible then just don't crank it anymore. And it works a lot better than wood!
  7. Feb 20, 2011 at 6:37 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I got rid of my bedliner for that reason, did a spray on everywhere and got one of those rubber bedmats, now nothing slides.
  8. Feb 20, 2011 at 7:24 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Yeah id remove the factory liner, I took mine off around 95k and the paint under the liner is pretty much gone. I don't care really but I'm glad I took it off so it didn't wear through the primer and start rusting.. just save your pennies and get yourself a real nice spray in liner
  9. Feb 20, 2011 at 7:53 AM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    This. I cut mine to follow the wedge pattern of the bedliner inserts and it works great.
    The only difference, I used 2X8's.
