Ideas on how to unfuck myself?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Active, Jul 31, 2019.
  1. Jul 31, 2019 at 10:07 PM
    Active
    Active [OP] Well-Known Member
    AZ
    2021 Tacoma 4x4 TRD OR
    I just barely kinda sorta STRIPPED THE LIFE out of the tailgate bracket screw.......
    Anyone have any useful ideas? Ive already beat my self up over it....now what do I do?
    Only the one on the right is stripped....at least I stopped after I did it to one.
    I basically changed the molecular structure of the metal
    Any help would be greatly appreciated before I fuck this thing up worse
    tonered and seanb06 like this.
  2. Jul 31, 2019 at 10:09 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Slot it with a dremmel and use a large flathead screwdriver.
  3. Jul 31, 2019 at 10:10 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  4. Jul 31, 2019 at 10:14 PM
    Qball808
    Qball808 Member
    HAWAII
    96 Tacoma 2.7
    All motor, intake,lce header,lce big bore throttle body, egr delete,flex fan , lce lighten drive pulley , magnaflow high flow catalytic, flowmaster can. 285/70/17 AT toyo’s :::: Mods 2B done::::: <lce stage 3 head & cams <Lce high boost charger kit/w/maf control <Lce tundra brake conversion <Pistons & rods <Piggy back ecu <4:88 gearing <Oil filter relocation & cooler <Transmission cooler/with fan
    I think the gat comes off any how lower down there should be a slot where one end pulls outward kinda in a 45 degree angle I think the pass side. Then u can cut a slot in the screw bolt and use a impact screwdriver to remove it. I’d cut slots with a die grinder I’ve done it just gotta have control so you don’t massacre your gate lol. That or weld a nut/bolt to it and remove that way. Good luck ...
  5. Jul 31, 2019 at 10:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  6. Jul 31, 2019 at 10:21 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Take the gate off to have more space. Find a bit bigger size torx head and hammer it in there.
  7. Jul 31, 2019 at 10:22 PM
    mcm808
    mcm808 Well-Known Member
    Micah
    Kane’ohe, O’ahu
    3rd gen
    slot it like the other guy said, with a Dremel then remove the plastics and heat the shit out of it up with a heat gun. throw on some lubricant and hit it with an impact screwdriver. good to go
    oconnor, Active[OP] and Qball808 like this.
  8. Jul 31, 2019 at 10:24 PM
    therealprotaco
    Gilbert, AZ
    I just noticed you’re in AZ...where at? I have a dremmel, hand impact driver, etc. we can get it out.
  9. Jul 31, 2019 at 10:32 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Too late now, but a impact driver is your friend.
    Bought this Craftsman one over 30 years ago. It's served me well.
    Those damn bolts that soft? I've been meaning to remove the same one you mutilated.
  10. Jul 31, 2019 at 10:37 PM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    You used a 1/4" drive ratchet?
  11. Jul 31, 2019 at 10:41 PM
    therealprotaco
    Gilbert, AZ
    Yeah 1/4” drive is a bad plan. An extension is also a bad plan.
    QuicksandTaco and Active[OP] like this.
  12. Jul 31, 2019 at 10:48 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    If slotting it doesn’t work you can use a broken screw extractor. Helps get stripped screws out too.
  13. Jul 31, 2019 at 11:21 PM
    Active
    AZ
    Yeah doesn't sound at all like I could fuck that up lol
    Thank you though
  14. Jul 31, 2019 at 11:22 PM
    Active
    AZ
    They're not that soft......Basically im a beast
    BlakeM, BassAckwards and 503TRD_22 like this.
  15. Jul 31, 2019 at 11:28 PM
    Active
    AZ
    ......um........yes?
    I have an SBR M4 with some LAP 5.56x45mm 62gn rounds but I figured that would obliderate the entire tailgate hingeand send shrapnel fuck knows where..... so I used monkey tools and did slightly less damage.
    honda50r likes this.
  16. Jul 31, 2019 at 11:30 PM
    Active
    AZ
    Yeah.....
    NOW i know!
    Fml
  17. Jul 31, 2019 at 11:35 PM
    Active
    AZ
    And you think that'll give me enough leverage to grip abs screw and get it out?
  18. Jul 31, 2019 at 11:38 PM
    Active
    AZ
    WHEN YOU'RE A HAMMER
    EVERYTHING LOOKS LIKE A NAIL
    That's what ima change my status to
  19. Jul 31, 2019 at 11:41 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Worst case drill it out. Because of the shape of the head, if you put the right size drill bit in it, it’ll act like a rivet when drilled. Leave threads showing to grab onto as well.
  20. Jul 31, 2019 at 11:43 PM
    mcm808
    Micah
    Kane’ohe, O’ahu
    3rd gen
    yah bro. remove plastics. lube it up with some sort of tri-flow or variation. slot it. heat it the fuck up. impact screwdriver. it comes out. Done
