Ideas on how to unfuck myself?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Active, Jul 31, 2019.
  1. Aug 1, 2019 at 10:00 AM
    #41
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Take a hex bit and pound it in. You want it really tight and pound the shit out of it, it should be stuck in the head, then use a longer 3/8 ratchet. Your welcome.
    Active[OP] and Superhulk LB like this.
  2. Aug 1, 2019 at 10:02 AM
    #42
    eon_blue
    Azusa, CA
    This ^ That's how I got my stripped front diff plug off.
  3. Aug 1, 2019 at 10:22 AM
    #43
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    My suggestion as well. Either the screw comes out or you end up drilling through the head. Either works and much better than normal bits. That said get a quality set. That applies to either bits or easy outs. If you break off either one in there good luck drilling through it...
  4. Aug 1, 2019 at 10:24 AM
    #44
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
  5. Aug 1, 2019 at 10:27 AM
    #45
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    I've had to use all three of these methods before. At least one of them will work. Just make sure you try the larger torx first, dremel second if the first doesnt work, then easy out as a last resort.
    shakerhood[QUOTED] likes this.
  6. Aug 1, 2019 at 10:59 AM
    #46
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    BTDT. My fix so far has been touch up paint until I get motivated enough to pull the TG off.
    Good luck.
    Active[QUOTED][OP] and Skydvrr like this.
  7. Aug 1, 2019 at 11:09 AM
    #47
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I'd probably start with an impact driver with the largest bit that will fit first.
    Then slot and try with the impact driver. Try not to make the slot wider than the bit you are going to use with an impact driver.
    Then maybe cut the head off and drill it out.
    Those easy outs can be great, but if you've ever broken one off in a hole, they don't drill out easy.
    tonered likes this.
  8. Aug 2, 2019 at 10:10 AM
    #48
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    My thoughts exactly. If you don't understand as explained, let us know.
  9. Aug 2, 2019 at 10:13 AM
    #49
    The_Devil
    E
    I've noticed that several bolts were T27. Can be an issue if T25s are used.
    tonered likes this.
  10. Aug 2, 2019 at 10:14 AM
    #50
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    C4?
    WiscoPat likes this.
  11. Aug 2, 2019 at 10:24 AM
    #51
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    There's plenty of good advice already, so here's my comment to cheer you up OP.
    The title of this thread is absolutely phenomenal - just like you! :bananadance:
    But seriously, it's refreshing, especially among the monotony of "my truck does/doesn't do 'x' and therefore sux" and not being capable of identifying what a search bar is used for, aka "what size tire can I fit without a lift."
  12. Aug 2, 2019 at 10:35 AM
    #52
    The_Devil
    E
    My favorites are the endless Pro grill questions and posts.
    WiscoPat[QUOTED] likes this.
  13. Aug 2, 2019 at 10:40 AM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Unfortunately, these are T40. I had two different tight fitting bits and I still cammed them out. I was completely straight on. Either the paint got it or possibly the shallow engagement did me in.
  14. Aug 2, 2019 at 11:12 AM
    #54
    AgingDisgracefully
    AgingDisgracefully Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    The only sensible technical solution is to trade it in for a 2020.
  15. Aug 2, 2019 at 11:13 AM
    #55
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Only after a part out.
  16. Aug 2, 2019 at 11:14 AM
    #56
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Or, steal someone else's tailgate?
    AgingDisgracefully likes this.
  17. Aug 2, 2019 at 11:14 AM
    #57
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    You could get a plasma cutter and cut the whole section out.
    tonered likes this.
  18. Aug 2, 2019 at 11:15 AM
    #58
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Do those work on composite?
    Wixo[QUOTED] likes this.
  19. Aug 2, 2019 at 11:16 AM
    #59
    Itchyfeet
    Itchyfeet Well-Known Member
    Don't forget the endless raptor light installs. The person that started that mod needs to be sentenced to no less than sixteen lashings up until they lose control of their bowls or pass out
  20. Aug 2, 2019 at 11:18 AM
    #60
    AgingDisgracefully
    Peter
    Its always ugly when they lose control of their bowls. At that point mugs and plates cannot be far behind.
