Ideas to help with rub
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sah3167, Sep 30, 2021.
  1. Sep 30, 2021 at 6:31 PM
    sah3167
    sah3167 [OP] Well-Known Member
    16 Tacoma TRD Sport 4x4 DCLB
    Kicker speakers all around Remote Start Screen ProTech Bed Lighting Pro Grille
    I recently bought a set of oem sema pro wheels with 265/70/r17 tires and put them on my 16 trd sport dclb and I get rubbing when making a turn over a small curb or up a driveway. I am more of an oem guy so don’t want anything huge but looking for a small lift in front but most importantly don’t want a level look as I like the stock rake. I also tow a 4,000lb boat so don’t like the idea of notching a 5100 shock up a bit as it would change the ride quality. Thoughts on 1.5” lift for front and back?
  2. Sep 30, 2021 at 6:39 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Bilstein 5100's and a 1" block in the rear would be fine for what you are looking for. The system is designed to adjust height with the different notches with out affecting ride quality. (Or add-a-leaf to get the 1.5" in the rear. I wouldn't go bigger than a 1" block in the rear.)
    As for rub, the lift won't prevent it. Just change when it happens. So your best bet is to see where it is rubbing and modify whatever it is rubbing on to solve the issue. Most likely a little grinding of plastic will solve the issue.
  3. Sep 30, 2021 at 6:42 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Let'r rub! That's Tacoma life. :thumbsup:
    sah3167[OP] likes this.
  4. Sep 30, 2021 at 6:45 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    5100s all around with airbags!! no AAL!! Are you rubbing the mud flap?
  5. Sep 30, 2021 at 6:47 PM
    sah3167
    I have heard when you notch the 5100 up is compresses or extends the shock and you get a different ride from it. My worry is more the affect it will have with towing as opposed to the feel
  6. Sep 30, 2021 at 6:50 PM
    sah3167
    great question, I do have the mud flaps on but since I only have had the new tires on for 100 miles I have not been able to pin point the rub just yet. Are you saying to put the 5100 up a notch? Also, the airbags would just be for bed sag right? Not for lift?
  7. Sep 30, 2021 at 7:30 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    You have heard incorrectly. When you change notches on the strut the spring height is unchanged. The change is in how much of the strut shaft is exposed.
    Stock you have 8" of travel and 4" of shaft exposed. 4" of up travel and 4" of down travel.
    Lifted 1½" you still have 8" of travel but now you have 5½" of shaft on the strut exposed. This changes the travel to 5½" of up travel and 2½" of down travel.
    Changing the notch height only changes the ride height and where the suspension sits in the its travel.
    Edit: These numbers are not representative of the actual struts values. They are just numbers to help explain how the adjustment works.
  8. Oct 1, 2021 at 4:29 AM
    sah3167
    great explanation! Really appreciate it. So the notching helps lift the front a bit and then on the rear, just put a block in? Or AAL
  9. Oct 1, 2021 at 4:31 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Lube :anonymous:
    vivid02 likes this.
  10. Oct 1, 2021 at 5:01 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Yes. At most a 1" block, or an Add-a-leaf system if more is desired. Now it is important to understand that a block does not change the spring characteristics but the Add-a-leaf does. It will make then firmer because it physically arches the spring to obtain the desired lift and depending on the system add more leaves to the spring pack.
  11. Oct 1, 2021 at 5:04 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    You should be able to clear 265/70/17 on stock suspension easily, (assuming 6 lug truck) have you taken your truck in to get a high caster alignment?
  12. Oct 1, 2021 at 8:19 AM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    …..with a Fleshlight…..
    Chunk[QUOTED] likes this.
  13. Oct 1, 2021 at 8:22 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Drive more and your tires will wear down and not rub. :rolleyes:
  14. Oct 1, 2021 at 8:47 AM
    sah3167
    I took it in and alignment was all green, said camber was all good and wheels were balanced. is a high caster alignment different? Yes they do not rub 90% of the time but when I turn a certain way going into a driveway or gast station they rub. It is 6 lugs and OEM sema wheels from 4runner pro
  15. Oct 1, 2021 at 8:52 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
  16. Oct 1, 2021 at 11:18 AM
    EasternSun_72
    EasternSun_72 New Member
    Tristan
    2012 Green Tacoma
    Changed Rims/Tires
    Yeah, I got all terrain tires on a stock 2012 non-trd, and I ended up having to take off the front mud flaps.
    Even then, it still rubbed, so my dad recommended we grind the plastic.
    It works great now, and coincidentally, it only rubs when going to a gas station or entering the driveway. It's pretty harmless, so I'd give it a go, unless you think it won't make much of a difference.
  17. Oct 2, 2021 at 2:39 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Totally not true. I have two set on different setting. Bad info ^right there!!! I run 265/70s on my 4runner Pro wheels and no rub, however try an alignment and a good front end mechanic can fix the rubbing, as you shouldn't be rubbing.
  18. Oct 2, 2021 at 3:17 AM
    Key-Rei
    Key
    Florida
    Yes a high caster alignment forces the wheels forward, typically +2°, your caster will be in the red, that's fine, your camber and toe are what effect tire wear and tracking, caster won't.
    That said you may need aftermarket upper control arms for more caster.
    I have 3.5° forward caster IIRC and still have "green" for camber and toe.
    Otherwise you may want to add some 1/4 top hat spacers for a "level" up front and or trim or remove your mud flaps if you still have them.
  19. Oct 2, 2021 at 3:41 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    You probably are rubbing the uca if you’re running the factory offset wheels. Cut the wheel and back up or go forward. Hop out and see what’s rubbing. Then you’ll know what you need. Lift vs less offset
  20. Oct 2, 2021 at 4:34 AM
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    Agreed!
    My Tacoma causes rubbing every time I think of it in the shower.
