Identify this lower, center dash or console connection?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oconnor, Aug 24, 2019.
  1. Aug 24, 2019 at 3:36 PM
    oconnor
    oconnor [OP] Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    So I jumped the gun and tore my dash apart early this week and am putting it back together today and just cannot figure out where this connector goes. Any ideas?
  2. Aug 24, 2019 at 3:39 PM
    oconnor
    Midwest
  3. Aug 24, 2019 at 3:40 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Plugs into something
    daddy_o likes this.
  4. Aug 24, 2019 at 3:43 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Probably plugs into the one thing that doesn't work right now.
    StayinStock and tcjacado like this.
  5. Aug 24, 2019 at 3:43 PM
    Babybluetaco
    Austin
    09 5 lug
    Or the one thing that you have never used or ever will
  6. Aug 24, 2019 at 3:52 PM
    daddy_o
    Bossier City, La
  7. Aug 24, 2019 at 4:02 PM
    oconnor
    Midwest
    I have accounted for the OEM switch connections as well as the three I have added and the little night-light connection. I'm baffled. Toyota usually tapes up loose connections so this must be something. The illusive vibrating passenger seat perhaps?
  8. Aug 24, 2019 at 4:08 PM
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    can you zoom out a little so we can see where this connecter is that might help .
    oconnor[OP] likes this.
  9. Aug 24, 2019 at 4:19 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    How about the Qi charger?
  10. Aug 24, 2019 at 4:23 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
  11. Aug 24, 2019 at 4:28 PM
    oconnor
    Midwest
  12. Aug 24, 2019 at 4:30 PM
    oconnor
    Midwest
    I thought that at first but that one is all white and runs back toward the arm rest.
  13. Aug 24, 2019 at 4:45 PM
    hawaii_dave
    2017 trd pro
    auto trans ? plug into the left side of the shifter ?
  14. Aug 24, 2019 at 4:49 PM
    oconnor
    Midwest
    Sport AC 6MT 4x4.
  15. Aug 24, 2019 at 4:52 PM
    oconnor
    Midwest
    I pulled the HVAC panel above to make sure I hadn't pulled a plug from there while I was fat-fingering the rest but no, not from above.
  16. Aug 24, 2019 at 4:55 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Found it, goes right there
    Saeros and Beerpayzdabillz like this.
  17. Aug 24, 2019 at 5:17 PM
    hawaii_dave
    2017 trd pro
    connecter to inverter and armrest power outlet ?
  18. Aug 24, 2019 at 5:31 PM
    oconnor
    Midwest
    I don't see a connection for that.
  19. Aug 24, 2019 at 5:32 PM
    oconnor
    Midwest
    Now that I look at the back of the lower switch housing I see three or four dummy sockets below the switches. I think it may have come from there.
    Maybe an option the Base TRD Sport AC MT doesn't get... not sure why it would be plugged into a dummy socket unless this is something that can be installed by the dealer (whatever it is) and it's close to the hole so they can fish it and not tear the hole dash apart.
  20. Aug 24, 2019 at 5:51 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    If the auto has an illuminated gear selector it might be for that. Since yours is a manual it would not be needed. All the Toyota I have worked which had plugs not used were left as is unless the circuit required a loop.
