Identify this please
Discussion in 'Suspension' started by Tacoma414, Mar 19, 2011.
  1. Mar 19, 2011 at 6:05 PM
    Tacoma414
    Tacoma414 [OP] Well-Known Member
    Cody
    Agua Dulce
    06 PreRunner SR5 4.0L
    Flowmaster Exhaust 2" spacer lift 09 Tails blacked out Black headlight mod 6000k HIDs/Foglight mod Fog Light Mod 20" LED Light Bar Behind Grille Billet Grille Color matched mirros, doorhandles and bumper 5% tint all around Pioneer 4300dvd 2 10" kicker CVRs Alpine speakers Dome light: Blue LED Map light: White LED
    so i have both of those on my truck right now?
  2. Mar 19, 2011 at 6:38 PM
    rwcfrank
    rwcfrank Well-Known Member
    08 SR5 Prerunner
  3. Mar 20, 2011 at 8:02 AM
    Tacoma414
    Cody
    Agua Dulce
    Oh alright I see what you mean, I'm going to loose the soft bumper til I get the coil overs
  4. Mar 20, 2011 at 12:05 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Thats a 2 1/2'' leveling kit on the front.
  5. Mar 20, 2011 at 5:31 PM
    Tacoma414
    Cody
    Agua Dulce
    What is the spacer?
  6. Mar 20, 2011 at 6:52 PM
    Tacoma414
    Cody
    Agua Dulce
    should i go with bilstein 5100s then? cause it would be way cheaper than kings, but they said kings are great for high speed, and taking speed bumps and pot holes, idk im not sure
  7. Mar 21, 2011 at 12:22 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    there are a ton of guys on here that run the 5100's and love them. they are a nice, cheap way to lift your truck. set the lift any one of the the 3 setting they have and you are good to go.
    with coilovers you have to worry about having them rebuilt over time.
    if your lifting over 2.5" its nice to get aftermarket UCA's.
  8. Mar 21, 2011 at 12:44 PM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    Are you planning on doing alot of offroading at high speeds? - if so coilovers (like the kings you want) won't aren't going to be enough you would want new upper control arms and probably new spindles or get spindle gussets to beef up the spindle.
    Also consider just getting a full long travel kit if you are going to be mobbin it hard in the desert.
    I have new coilovers because i got a good deal on them and it made alot of different just driving on the street and light offroad.
    For the rear suspension just an add a leaf is a cheap cost for a smoother ride and a little lift.
  9. Mar 21, 2011 at 5:47 PM
    Tacoma414
    Cody
    Agua Dulce
    Yeah I'll just get the 5100s and a leaf in the back, it's nothing to serious, there's accasional braking bumps and pot holes, but if the 5100s can handle them I'll just do that and SAve a lot of money for other stuff, should I get a set of UCAs And ebach coils?
  10. Mar 21, 2011 at 5:52 PM
    Tacoma414
    Cody
    Agua Dulce
    I meant elbach springs
  11. Mar 22, 2011 at 5:48 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    if you want to. the billys will only give you 2.5" of lift
    your best bet is to just go to toytec's website and pick you a 3" lift that involves new shocks and or springs (billys or the OME lift) and you will be fine.
  12. Mar 22, 2011 at 9:03 AM
    Tacoma414
    Cody
    Agua Dulce
    Alright, so the 3" lift will level my truck out and give it the pre runner look In the front? Cause I'm keeping my back stock height
  13. Mar 22, 2011 at 9:25 AM
    mxnborder
    Santa Barbara
    yeah if you just go 3 in the front it will be really tilted prerunner, will look good though, i took out my add a leaf for a while but missed the smoother ride with it out
  14. Mar 22, 2011 at 9:51 AM
    Tacoma414
    Cody
    Agua Dulce
    Yeah I'll keep the leaf out so it rides smooth, but this is all on hold cause my truck isn't running right, it's starting to shake when I get around 30-50 mph, so hopefully my warranty covers it, but thanks for the input guys, so 3" lift in front, bilstein 5100s all around, and elbach springs
  15. Mar 22, 2011 at 10:19 AM
    #35
    mxnborder
    Santa Barbara
    dude i'm a little confused what your trying to accomplish here, the spacer you have on it right now is probably 2.5 - 3" of lift so taking that off for something else won't get your front end much higher. If you aren't doing much offroading or atleast very hard then you will be fine with the spacer lift you have on it right now.from the look of how your truck sits it almost looks like it has an add a leaf in the rear but could just be the picture cuz it looks pretty level. If you want it to be alot higher in the front you should look at a CST or Camburg lift spindle. Also when i said i missed the smooth ride i was saying it rides alot smoother with the add a leaf in the rear, when i took it out i realized how rough the stock ride is
  16. Mar 22, 2011 at 12:17 PM
    #36
    Tacoma414
    Cody
    Agua Dulce
    No I want to keep the same look, I just want to loose the rough ride from the spacers that's all, my truck is between .5-1" higher in the front, and I feel every bump off roading, and from what everyone said the bilsteins will take the bumps and make it smoother and that's what I want, and if the add a leaf helps I'll do that to even if it levels out
  17. Mar 22, 2011 at 12:39 PM
    #37
    mxnborder
    Santa Barbara
    Your truck is definitely more than 1" higher in the front,
    The spacer alone looks about 1-1/2" to 2" which pushes all your geometry down giving you almost 3" of lift.
    You can buy my icon coilovers from me for $800 and your current shocks and spacer :D
  18. Mar 22, 2011 at 8:13 PM
    #38
    Tacoma414
    Cody
    Agua Dulce
    yeah ill ask from my local shop for what i have, but nah im good, ill just get bilsteins but thanks though
  19. Mar 23, 2011 at 5:48 AM
    #39
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I dont know about you but the AAL I had in my last taco rode like shit and the tsb springs are only a little better than that...
    AAL will not make your truck smoother, it lifts it and gives you a little more payload capacity in the bed. adding leafs to a leaf pack will make it more stiff.
    but if you wanted smooth you could take out the overload leaf and get a 3 aal pack from either icon or wheelers off road. that replaces the one super thick spring with 3 thinner springs that are easier the bend thus making it smoother
  20. Mar 24, 2011 at 8:43 AM
    #40
    Tacoma414
    Cody
    Agua Dulce
    Well wouldn't thinner leafs make it bad to put stuff in the bed?
