Identify this Topper
Discussion in '1st Gen. Tacomas (1995-2004)' started by glsmaverick, Dec 20, 2010.
  1. Dec 20, 2010 at 4:30 PM
    glsmaverick
    glsmaverick [OP] Well-Known Member
    Howell MI
    96 Taco; 2.7l 4x4 5spd
    None
    So I am thinking about picking up this topper from a guy on CL. It looks like its in good shape and the price is right. He is not sure if it came off of a regular or ext cab because it was never mounted. It looks as though it will fit my regular cab and I like the design.
    Now the question is, who makes it? Its an older model from whomever but the rear lid struts don't work so I will need new ones and would like to know who to order from. Also in case I need any mounting hardware or anything. So help me out!
  2. Dec 20, 2010 at 8:10 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    at first glance it looks like it would fit an xtra cab best. (notice the angle near the cab? Reg cabs have a nearly vertical window, while xtra cabs have more of an angle.) idk what brand it is
    I picked up a used A.R.E. last month for super cheap and though it wasn't perfect for my truck, as long as the perimeter fits on your bed rails you are good to go. Get the mesurements and c if it will fit. You'l be very happy with it if you buy it.
    Good luck!
  3. Dec 21, 2010 at 3:15 AM
    glsmaverick
    Howell MI
    None
    So here's the question then; the bed dimensions between an xtra cab and reg cab are identical. The only difference is the cab angle (4 reg and 10 xtra). So will the top hit the cab before it gets completely flush with the cab side of the bed? This, of course, would lead to mass amounts of leaking into the bed which I would like to avoid.
  4. Dec 21, 2010 at 6:00 AM
    mikee72
    mikee72 Member
    tampa,fl
    01 single cab sst taco
    It will be fine I've got a extended cab topper on my reg cab and it works fine you just have to leave your bedliner in and it will let you slide the topper almost all the way up without hitting the cab but you may still have a small over hang on the tailgate side
  5. Dec 21, 2010 at 6:43 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    There's no way to tell for sure without test-fitting it. Different manufacturers' shells sometimes had different contours.
    Some XtraCab shells were designed to so closely match the XC rear cab wall slope that they'll clash with / butt into a Regular Cab's rear wall.
    Others will just have a noticeably odd 'gap'.
  6. Dec 21, 2010 at 11:28 AM
    glsmaverick
    Howell MI
    None
    Yeah, I'm torn really because I like things to look uniform and if this thing fits funny it will drive me nuts. I might pass it up and keep searching; something will have to turn up eventually. So far all I can find is double cab and extended cab tops that are within 3-4 hours of my place.
    I thought about perhaps buying it and then taking an angled section out and reducing the angle then glassing it back together, but a body shop friend of mine advised against it.
  7. Dec 21, 2010 at 12:47 PM
    TIPICOTACO
    Tyler
    nw nj
    I'd say if the cap is close enough to you, just cruise over and see how it fits. Bring a buddy and throw it up there to have a look. Make sure you protect your bed rails though cause the littlest speck of dirt will scratch your paint (ask me how I know :() The worst that could happen is that you don't like how it looks and you don't buy it. If the price is right its def worth a shot.
    I would advise against altering the top also.
  8. Dec 22, 2010 at 11:41 AM
    glsmaverick
    Howell MI
    None
    So I ended up saying nadda to that topper and went with one a bit farther away and a bit more expensive. But its exactly what I want and comes with the Yakima rack mounted. Colors wrong but I don't care.
    Thanks for everyone's advice though.
  9. Dec 22, 2010 at 11:47 AM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    If the price is right, I'd snag it up. You can always resell later if need be. Besides, the least you can do is check if it fits nice. Looks like its in great shape man! Nice find!
  10. Dec 22, 2010 at 12:22 PM
    TIPICOTACO
    Tyler
    nw nj
    Looks like a good find there. I need to add a rack to mine. Congrats and GL
  11. Dec 22, 2010 at 2:46 PM
    badboyrr
    badboyrr Well-Known Member
    spring branch TX
    Tacoma
    matching topper, rear air bags
    Paint it up! Nice topper.
  12. Dec 22, 2010 at 2:47 PM
    badboyrr
    spring branch TX
    Tacoma
    Oh by the way........how much for the donkeys?:D
  13. Dec 22, 2010 at 8:40 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I had several different camper shells on my 1997 regular cab Tacoma. The two extended cab versions did NOT work. I finally had to drive 9 hours to get a used regular cab shell (got it for a steal). Also, the extended cab shells (even if they "fit") will need to be slid towards the rear of the truck. A lot of times it makes a good water-tight seal difficult, if not next to impossible.
    After owning two Tacomas and 4 camper shells, I will tell you to opt for the one built for your truck and not try to half-ass one on there.
    Just my opinion.
  14. Dec 23, 2010 at 5:03 AM
    glsmaverick
    Howell MI
    None
    And thats what I did, thanks for the advice though. The red one above is for a regular cab Tacoma.
