Identifying a lift, wheel/tire options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MoonDogSwampFox, Dec 13, 2020.
  1. Dec 13, 2020 at 4:18 PM
    MoonDogSwampFox
    MoonDogSwampFox [OP] Active Member
    2016 Tacoma TRD Sport
    I'm a couple of weeks into my first Tacoma and I'm trying to work out some gremlins. I have some (hopefully slight) rubbing on my upper control arms as well as the dreaded 20mph vibration. I'm hoping I can fix the rub with some new wheels or at least spacers. And I'm going to look into replacing the needle bearing and hope that takes care of the vibration.
    Anyone want to help me figure out what size lift I have and what tire and wheel options that would give me? Linking a post in my build thread below with pics of the suspension.
  2. Dec 13, 2020 at 4:43 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Those are JBA upper control arms. The coilovers look like bilstein 5100s with OME springs(lift height depends on spring rate and perch clip used). the rear shocks are also bilstein 5100s.
    Since you have the front diff vibration, you're probably over 2" in the front.
    Edit: you have a ubolt flip kit with superbumps, and what appears to be a carrier bearing drop spacer as well.
    Edit2: looks like an add a leaf, not a dakar leaf pack.
    verynearlypure likes this.
  3. Dec 13, 2020 at 4:46 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Probably need shims in the back to fix the 20 mph shudder. If it goes away in 4wd you need the needle bearing replaced.
  4. Dec 13, 2020 at 4:47 PM
    StrikerVix9
    StrikerVix9 Member
    Victor
    2020 Tacoma OR
    Not a mechanic here, but those look like 5100 billsteins, generally the coil(specs) will dictate what setting your coil should sit at on those shocks. I would double check that they are not set too high for the coil. Have you tried balancing the tires?
    I think your wheel or spacer idea is great.
  5. Dec 13, 2020 at 5:34 PM
    MoonDogSwampFox
    Ah ok, I was going by the little Emu logo on the rearmost clamp. It doesn’t show in pic. But I guess that doesn’t necessarily mean Dakars.
  6. Dec 13, 2020 at 7:31 PM
    Silverlogic
    Tyler
    OME makes add a leafs too, but it's possible it's a dakar pack. Look up any numbers on it.
  7. Dec 13, 2020 at 7:48 PM
    MoonDogSwampFox
  8. Dec 14, 2020 at 11:06 AM
    phx taco
    phx taco GTH
    PIT to PHX by way of the ATL
    19 TRD 4x4 Sport, 06 LX470 (The Hate Tank), 96 4Runner 4x4 SR5,
    ICON Stage 4, 3TPAM, MESO MOLLE and 3rd Brake light, Pop & Lock
    Hoping to find some wheel experts here too!
    Icon 3" lift all the way around.
    Hoping to learn similar. Current Sport wheels are 17x7.5x +30 and I'm looking to buy 17x 8x +15
    Thinking this is a wash, but would love some experienced input here.
    Thanks in advance!
  9. Dec 14, 2020 at 11:20 AM
    Silverlogic
    Tyler
    I haven't seen many 17x8 +15 offset wheels( 0 offset is more common in that size) . However the 4Runner Trail wheels are 17x7.5 +15
  10. Dec 14, 2020 at 11:22 AM
    MoonDogSwampFox
    Measurement from the center of the wheel straight up to the edge of the fender flare edge is 23" in the front and 24" in the back. So that would seem to infer that I have a 3" lift all the way around too, if I'm not mistaken.
  11. Dec 14, 2020 at 11:25 AM
    phx taco
    phx taco GTH
    Thanks. Silver - I'm going to go take a look at them this week.
    Add reads -
    17” Bronze TRD style Wheels for Tacoma 4Runner Set of four brand new rims
    "Brand new set of four aftermarket TRD style wheels in matte bronze finish 17x8 with 6x139.7 bolt pattern and +15 offset 106.1 hub centric Works with factory Toyota lugs for Toyota Tacoma and 4 runner with 6 lug pattern"
  12. Dec 14, 2020 at 11:40 AM
    MoonDogSwampFox
    It appears that I have these 2016 4Runner wheels...|
    https://www.hubcaphaven.com/p/11060...j-cruiser-wheel-grey-machined-4261135540.html
    According to that site, they're 15mm offset. So if I wanted an extra inch behind my wheels, I think I'd be looking for something with -10mm offset.
    Also, just took a ride with my mechanic. I mentioned the needle bearing and ECGS bushing. He was dubious at first, but when he put the truck on the lift and saw how much play I have in my driver-side CV, he agreed that I need to replace the bearing very soon. I've ordered the bushing and seal, so hopefully this takes care of my vibin'.
  13. Dec 14, 2020 at 11:56 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Looks like the Bilsteins are set on or near the lowest setting. You see the little grooves in the housing that's where you adjust the height on these. Basically its like a snap ring you move up and down in the different grooves. If it is a 24-263108 then bottom groove is 0" lift, top groove is 2" of lift.
  14. Dec 14, 2020 at 12:14 PM
    Silverlogic
    Tyler
    Those settings are only valid if reusing the stock springs, When paired with aftermarket springs they're usually set to the lowest setting and the spring determines the lift. Which appears to be the case here.
  15. Dec 14, 2020 at 12:31 PM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    Ah ok.
  16. Dec 14, 2020 at 6:40 PM
    MoonDogSwampFox
    If I go the spacer route, anyone know what is the smallest spacer you can use without trimming the studs?
  17. Dec 14, 2020 at 7:38 PM
    Silverlogic
    Tyler
    Why are you wanting to push the wheels out further? Clearance or looks?
  18. Dec 14, 2020 at 8:13 PM
    MoonDogSwampFox
    Clearance between the tire and the UCA.
  19. Dec 14, 2020 at 8:50 PM
    Silverlogic
    Tyler
    Humm, according to the jba website you shouldn't be rubbing with those size tires and wheels.
  20. Dec 15, 2020 at 4:43 AM
    MoonDogSwampFox
    It’s not much and it’s definitely only when I’m holding the steering wheel all the way in the turned position. Maybe it’s not a big deal?
