Identifying Limited Slip Differential, 05 Pre-Runner, 2WD, V6 Engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Jul 14, 2007.
  1. Jul 14, 2007 at 6:15 AM
    parfleet
    parfleet [OP] Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    I have an 05 Tocoma Pre-Runner, V6 Engine, 2WD. I am attempting to determine if I have a limited slip differential. Members of the Tocoma Discussion Forum have advised me that the differential has a LSD mark on the differential somewhere. I called the local Toyato Dearlership Service Department and I would have been better off posing the question to the "Space Station".
    My differential has a "Bar Code" and then the following letter/number combination: C5 070705 and under this is 0419. Am I truly safe in assuming this IS NOT A LIMITED SLIP DIFFERENTIAL?
    Help Me Please!
    Rex from Pensacola,FL.:confused:
  2. Jul 15, 2007 at 1:10 PM
    wrxed96
    wrxed96 Well-Known Member
    Mine says LSD Oil only, and it has a different part number begins with c6
  3. Jul 15, 2007 at 6:18 PM
    flyman767
    flyman767 Well-Known Member
  4. Jul 16, 2007 at 5:52 AM
    parfleet
    Rex
    Pensacola, FL.
    Thanks! That must be it then....C6 must ID a limited slip.
