Identifying the cause of suspension replacement failure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Jan 10, 2024.
  1. Jan 10, 2024 at 4:07 AM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I have to figure this out before I proceed.
    I replaced my whole front suspension in 2019. I got stock TRD Sport struts from a 3rd Gen to give me a 1" lift (I also added a leaf to the rear to bring that up 1"), I got UCAs from a guy with a 3rd Gen here woth low miles, ProForged inner and outer tie rods, and replaced the bushings and ball joints on the LCA with moog (greasable ball joints).
    In 2021 I started getting a bad popping and clunking out if the front right suspension and now by '23 it was worse. Brought it to get looked at and they said everything was torqued correctly and the specs looked good but the LCA ball joint went and in doing so, had worn out every other part of the suspension. :(
    One thing of note- when I put everything on in '19 and got an alignment, they absolutely could not get the truck aligned. I took it to 3 places and it still never got fully aligned.
    Anyway, I need to replace everything again. I was going to swap out the struts with another set of third gens, and probably Moog LCAs and tie rods. But I need to make sure the same issue doesn't occur again! Any ideas what may have caused that? Could it have been a faulty ball joint to start?
  2. Jan 10, 2024 at 4:56 PM
    slossboss
    slossboss Well-Known Member
    Troy
    FL
    2013 TRD Sport 4x4 Nautical Blue Metallic
    Considering you could not have the truck aligned properly, I would think that to be more likely to cause issue than the chance of receiving a faulty joint. Wonder what the alignment showed and if it would have had any clues to what caused poor alignment.
    Poor suspension geometry ? You’re gonna have a bad time
  3. Jan 10, 2024 at 9:58 PM
    The605taco
    The605taco Well-Known Member
    Sawyer
    2014 4X4 short bed
    6112(notch 3) 5160 icon AAL Baja fogs and Ditch lights Headwaters seat covers Off roam phone mount Diamond back cover
    There is many things that could be wrong, but I just had a ball joint replaced after driving a solid 10k on it not being ok because I thought it was the sway bar making noise.
    My theory here is the upper control arm is designed for much more lift than what you have so this is the result they couldn’t get it aligned and everything’s having issues. That’s the biggest issue I see possible on this setup. I am on 1.5” on stock uac and the alignment is perfect and has been for years. Even with a bad ball joint. And I am a heavy off roader.
  4. Jan 10, 2024 at 10:13 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Hmm, so I may be better off going back to stock uppers for a second Gen, huh? I really dont want to do this all over again
  5. Jan 10, 2024 at 11:33 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Am I reading this correctly that you had a problem starting in 2021 and did nothing about it until now (2023)? Should have figured out the root cause back in 2021. Lack of maintenance is what caused all of this, not a magical combination of parts.
    OEM Toyota LCAs are the best. Hands down, end of story. If you don't want to do it all over again, use OEM Toyota parts. Same goes for UCAs if you only have 1" of lift, OE will handle that just fine. Same goes for tie rods. Toyota genuine parts.
    Moog ain't what they used to be, quality is more mystery meat than quality any more.
    Jakerou likes this.
  6. Jan 11, 2024 at 1:34 AM
    TacoTuesday1
    FL
    Not sure what you’re asking.
    all I’ve gathered from original post is that you took the truck to a bunch of Jimbobs
  7. Jan 11, 2024 at 5:06 AM
    The605taco
    Sawyer
    2014 4X4 short bed
    Kinda sounds like it. I’m a little confused on how you got the lift physically because just changing the strut to a different stock one shouldn’t change much.
  8. Jan 11, 2024 at 1:22 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I started looking into it when it started. First two shops I went to couldn't find anything wrong, but the clunking continued. Then, a few months ago took it to a new place and got this diagnosis. So, more may have worn out in that time
  9. Jan 11, 2024 at 1:23 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I switched from the stock 2nd generation struts to the stock 3rd Gen struts. I know a lot of guys on here did that and it provides about a 1" lift in the front. I wasn't sure if that change in geometry may have altered other stuff, tho that I wasn't aware of, despite having changed all the other suspension parts
  10. Jan 11, 2024 at 1:30 PM
    PROBTO
    PROBTO Active Member
    Mixing 3rd Gen and 2nd Gen parts is most likely the issue here. Some parts are interchangeable but if you're looking to square it all up I'd go ahead and get the actual oem parts needed and work on a lift from there. You've got some worn parts already *noted from the clunking* so you might as well td some maintenance and go through each piece so you can get your geometry back in line.
  11. Jan 11, 2024 at 2:20 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I'm going to replace it again, because I don't want to risk something being too worn at this point. But definitely don't want to allow this to happen again
  12. Jan 12, 2024 at 7:01 AM
    The605taco
    Sawyer
    2014 4X4 short bed
    I would just start from the base I’m on 1.5” of lift and did absolutely nothing besides the struts and an alignment after install. Had no issues that were caused by this.
  13. Jan 12, 2024 at 8:41 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    That's what I'm talking about. Am hoping for no issues you
  14. Jan 12, 2024 at 8:42 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Here's a question- I have oem LCA with moog ball joints in them. Should I just replace the bushings and ball joint and keep the arm? It's probably the same price to buy some Moog LCA, tho I don't love that company
  15. Jan 12, 2024 at 9:11 AM
    The605taco
    Sawyer
    2014 4X4 short bed
    I just had one ball joint replaced in the last month due to failure. Not because of suspension or anything just seemed to be a wear item and honestly with how j drive I’m surprised it took this long.
    Was replaced with a Napa like high quality one. I want to say it was $80-130 can’t remember off the top of my head. (Greasable one)
  16. Jan 12, 2024 at 12:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    How does a bad lower ball joint case the “whole” front suspension to “go bad”?
    You got more than a bad ball joint problem.
  17. Jan 12, 2024 at 1:09 PM
    TacoTuesday1
    FL
    cuz Billybob said
    TnShooter[QUOTED] likes this.
