Idiot Lights Staying Lit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ldvo, Mar 21, 2010.
  1. Mar 21, 2010 at 3:24 PM
    ldvo
    ldvo [OP] Member
    Boston
    Tacoma TRD 4WD
    push bar, foglights
    When I started the engine after installing a set of PIAA 540 fog lights, the idiot lights for ABS, Brake & LSD remain lit constantly. I disconnected the battery for a couple hours but nothing changed. I checked ABS #2 fuse and it seems to be OK. What caused this problem and how do I fix it?
  2. Mar 21, 2010 at 3:27 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    like the parking brake light? Is the VSC off light on or off?
  3. Mar 21, 2010 at 3:43 PM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    How exactly did you power your lights? Did you clip or splice into any wires? Did you disconnect anything to get it out of the way for the install?
  4. Mar 21, 2010 at 8:42 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    maybe it's trying to tell you something.
  5. Mar 22, 2010 at 5:07 PM
    ldvo
    ldvo [OP] Member
    Boston
    Tacoma TRD 4WD
    push bar, foglights
    The VSC light is on.
  6. Mar 22, 2010 at 5:10 PM
    ldvo
    ldvo [OP] Member
    Boston
    Tacoma TRD 4WD
    push bar, foglights
    The kit included a black wire and white wire for power and gound to the lights. Both included eyelets. I put both connections on a lug at the battery. The power for the relay was installed on the green wire at the driver's side running light. The kit included a clip to tie into the green wire. Nothing was disconected.
  7. Mar 22, 2010 at 5:25 PM
    SManZ
    Haymarket, VA
    Thats weird...none of these should have anything to do with ABS. I do know that if ABS is not working then VSC will not work since its dependent on ABS.
    Just to be sure, try disconnecting the green wire from the relay and seeing if that cures your problem.
    How did you route the switch?
  8. Mar 23, 2010 at 3:44 AM
    ldvo
    ldvo [OP] Member
    Boston
    Tacoma TRD 4WD
    push bar, foglights
    To get the switch wire through the firewall, I made a hole through the boot covering the wire harness.
    I got another response to my thread from someone that had the same problem after installing foglights. The dealership replaced a "shorted out frozen" brake actuator. It seems more than a coincidence that we both installed fog lights and then had the same problem. I still have more work to do on the foglights because they won't work when the driving and headlights are on. Did you happen to read my other thread about power to fog lights?
  9. Mar 23, 2010 at 3:58 AM
    SManZ
    Haymarket, VA
    If you have DRLs these turn off when the headlights are on. If you spliced into a DRL for the relay then thats why its not working when your headlights are on. Check and see that whatever bulb you tapped the relay into is lit when your headlights are on. You might want to look into the foglight anytime mod.
    Did you check the wiring harness around where you ran a hole through the boot?
  10. Mar 25, 2010 at 2:49 PM
    ldvo
    ldvo [OP] Member
    Boston
    Tacoma TRD 4WD
    push bar, foglights
  11. Mar 25, 2010 at 3:07 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    So the first thing to do is disconnect all the wiring that you installed for the fog lights. Make sure everything works normally when your lighting wires are disconnected.
    It is not a coincidence that you're having problems right after you did some mods. After you verify everything works normally, re-connect your new light wiring, wire by wire, and see what connection is causing the problem.
