Idiot's guide to Crawl Control, MTS and Locking Diff?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZachMX, Dec 7, 2016.
  1. Dec 7, 2016 at 7:24 PM
    ZachMX
    ZachMX [OP] Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I thought so, saw thats how you can do some sick slide/donuts by locking it up in snow.
  2. Dec 7, 2016 at 7:38 PM
    NC_Mtn_Taco
    NC_Mtn_Taco Member
    Jordan
    2017 White Tacoma DCOR
    Yeah you probably can, if you look on your driver side door at the warning sticker it actually says don't go over 5MPH with the rear locker turned on though :/
    ZachMX[QUOTED][OP] likes this.
  3. Dec 7, 2016 at 7:54 PM
    flynnr
    flynnr Well-Known Member
    2016 TRD ORDC
    Interested also
    ZachMX[OP] likes this.
  4. Dec 7, 2016 at 8:26 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    There's a cheat sheet card on your drivers visor. Read it and follow the directions. As for crawl control when you change the knob your dash screen tells you what each mode is. Just make sure when you shift into high or low 4x4 that the light is solid and not flashing when you need 4x4. If its still flashing your not all the way into gear in the transfer case. So dont get into rough stuff until you get fully into gear.
    Law950 likes this.
  5. Dec 7, 2016 at 8:41 PM
    ZachMX
    Thanks I'm familiar with 4wd just not with all the new gizmos lol thanks!
  6. Dec 9, 2016 at 3:14 PM
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Went into the swamp this morning with the dog doing some hunting and tested out some of these controls. They work well enough. Like most things, it takes some practice to get used to. I didn't turn MTS up to the rocks setting because I was mostly in mud or water. But it chugged right through the stuff pretty well for me. I could have probably pushed through it without the MTS turned on, but this made it kind of "look ma', no hands...".
  7. Dec 9, 2016 at 3:23 PM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Also, I didn't enjoy the Crawl Control on a flat muddy or dirt surface. Definitely for situations where you are actually trying to crawl up a rocky area. Or if your trying to auto-pilot the parking blocks at the mall.
  8. Dec 9, 2016 at 4:10 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    I'm gonna start a crawl control school for 3rd gen owners. Well meet at the trails and I'll show you how to use it.
  9. Dec 9, 2016 at 4:44 PM
    tacitos
    16 TRDORDCLBJBL
    I crawl controlled over some speed bumps at the mall before.. Everyone was checking me out all jelly.
  10. Dec 9, 2016 at 5:15 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I like that the Off-Road Tacomas have different levels of "help". If not 2wd, then Auto LSD, then 4WD Hi & Lo, then rear locker, MTS, and crawl control. Unless I'm imagining things, I've used the rear locker with MTS and crawl control too.
    From my readings, it sounds like the MTS can serve as a middle ground between open and locked diffs. Which is good for the front wheels, since there's no locker.
    The locker has helped me out in more than one instance in the couple months of wheeling. Only used Crawl Control for testing.
