Idle and acceleration trouble after tension arm replacement
Discussion in 'Technical Chat' started by Eshelby, May 2, 2024.
  1. May 2, 2024 at 10:23 PM
    Eshelby
    Eshelby [OP] Member
    2011 TRDSport 4x4 6cyl
    I replaced my tension pulley and arm last night due to pulley chatter. The pulley had noise in it when I spun it, but Toyota doesn’t service the part so I replaced the entire arm. On my 2011 that means removing the fan and shroud, battery, alternator, and ac compressor. Everything came out and went back in smoothly. All electrical was plugged back in (I double checked). Started it up and died instantly. Started it again…runs fine. Ok, now I step on the gas and it bucks. Drive to the first stop sign. Stop. Step on the gas, it bucks again. I can feel the engine trying to smooth out the idle, it’s speeding up and slowing down on its own. Next attempt at accelerating from a stop and the engine revs, but the truck doesn’t move for a second or two then lurches forward. None of these issues were happening before the repair. Any ideas?
  2. May 2, 2024 at 10:31 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Make sure you didn't pinch the crank sensor wire, it runs behind the A/C Compressor.
    Do you have a CEL on? If so have you checked for codes?
  3. May 2, 2024 at 10:43 PM
    Eshelby
    Eshelby [OP] Member
    My light was on for oil change. I did an oil change during the repair. I can’t seem to get the light off, so there may be a code. I don’t have a tester. Not really wanting to drive it this way. I was worried driving it would cause damage to other parts. I kinda play at auto repair. I’ve never had any formal training. I just use the repair manual.
  4. May 2, 2024 at 10:54 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Check Engine light doesn't come on for an oil change, it indicates a problem in the powertrain management system.
    The Maint Reqd light is the oil change reminder, the reset procedure is in your owners manual.
    If it's running as poorly as you say I wouldn't reccomend driving it.
  5. May 2, 2024 at 11:02 PM
    Eshelby
    Eshelby [OP] Member
    Only light is maint req. I’ve reset it, but it’s still on. I’ll look at the crank sensor wire tomorrow. Someone suggested a damaged vacuum line. Thanks for the help.
  6. May 3, 2024 at 3:54 PM
    Eshelby
    Eshelby [OP] Member
    Ok, the plug on the ac compressor was only half way connected.
  7. May 3, 2024 at 4:21 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Glad you found it!
    Thanks for posting so others know where to look.
  8. May 3, 2024 at 6:04 PM
    Eshelby
    Eshelby [OP] Member
    A retired fleet mechanic at the auto parts store told me to check for loose or damaged vacuum lines and loose or disconnected electrical plugs. He said the ac compressor was sending signals to the computer and the computer was confused so it didn’t know what signal to send the engine. It was weird, the engine didn’t remember how or when to accelerate. Kinda felt like a bad transmission problem. He said in the next 80 to 100 miles the computer will reset the timing on the engine and smooth everything out. I cannot believe a plug can cause that much trouble!
