idle concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheHansen, Sep 22, 2010.
  1. Sep 22, 2010 at 6:25 AM
    TheHansen
    TheHansen [OP] Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
  2. Sep 22, 2010 at 7:24 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    First thing I always do with a "new to me" vehicle is inspect everything: plugs, wires, air filter, tires, brakes, etc. This will eliminate all doubt as to their condition and you might find other problems before they give you hell
    I don't recall seeing my truck do that. Usually it idles high on cold start, then slowly goes down to normal. Check the air filter and tell me what you find. Odds are, everything else is ok.
  3. Sep 22, 2010 at 7:27 AM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    It's the same on my 09.
  4. Sep 22, 2010 at 8:18 AM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    I have yet to check out the plugs, but i have put in an afe pro dry s drop in, removed the secondary charcoal filter, and changed the oil over to mobil 1. I am averaging about 21.5 mpg on my past few tanks so i doubt my plugs are bad. This is the only time it does this and it does not have any problems idling after the first 25 seconds of a cold start. I have a scan gauge, is there anything i could watch at start up to maybe help diagnose this?
    Maybe it is nothing then if yours does it too.
  5. Sep 22, 2010 at 8:32 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    Start out with disconnecting your battery, reset your ECU.
