Idle issue and weatherstrip removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by CVP71, Jan 18, 2009.
  1. Jan 18, 2009 at 8:28 AM
    CVP71
    CVP71 [OP] Member
    SR5 PreRunner Super White
    Headlamp relay/wiring upgrade w/Sylania SilverStar Ultras.
    Hi Guys!
    I have a 2004 Taco SR5 PreRunner w/ 165k. When sitting still, in neutral, it has a very slight rough idle. The spark plugs have been replaced, it was Seafoamed a few months ago, and the breather filter has been changed as well. Otherwise, it runs great when moving.
    I need to replace the outer weatherstrip on the left door. I have the FSM I downloaded through this site and it tells me to remove the door panel and the outside rearview mirror. I wasn't sure if the manual meant this to be if you're completely removing all of the door components. It appears the rearview mirror will need to be removed so I can remove the weatherstrip, but I am unsure. I didn't want to go through all that work if it could be removed otherwise. The manual says to use a screwdriver to remove the weatherstrip.
    Your input is greatly appreciated.
