Idle issue caused by battery replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HOGDOG76, Oct 1, 2016.
  1. Oct 1, 2016 at 7:37 PM
    HOGDOG76
    HOGDOG76 [OP] Active Member
    GEORGIA
    08 Hunting Tacoma
    I replaced my battery earlier today because it is four years old and not holding a charge. Now it is idling rough to the point of stalling out when you brake at stops. Alternator putting out 13.5 vdc and it is not throwing any codes. Any suggestions appreciated.
  2. Oct 1, 2016 at 7:39 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Some of the settings have been reset by the battery replacement. Once you put some more miles on the truck it will act normal again.
    10trdtaco likes this.
  3. Oct 1, 2016 at 7:55 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Often if you just rev it to 1500 rpms and hold it there for a minute or so, it will behave normally again.
  4. Oct 1, 2016 at 10:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ECU was reset when the battery was removed. Drive it a bit and it will straighten out.
