idle issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by YoTaVIdA, Dec 20, 2013.
  1. Dec 20, 2013 at 11:51 PM
    YoTaVIdA
    YoTaVIdA [OP] NWEST
    Portland, OR
    2001 SR5 Imperial Jade
    01 Tacoma 3.4L
    Hey everyone i've had this P0171 code for about a month so two days ago i began to get some maintenance done. I began by tossing some Seafoam in the vacuum line from the brake booster, in the crank case, and gas tank. I ran the crap out of it for two days and it felt like i had a brand new engine! TODAY, I went in and replaced plugs and wires with factory plugs (Denso) and NGK wires. While i had things apart I cleaned the TB and I pulled off the MAF sensor and cleaned it with CRC MAF sensor cleaner. When i put everything back and turned on the truck it idled at 2500 which i thought was okay because the truck was completely cold. After about 15 min the truck was still idling at 2200rpm so i turned off the truck. When i turned it back on the idle was at 1000 so i took the truck for a spin and drove for about 30 min. At every stop the idle was between 1900-2400rpm. Ive checked all the lines and everything seems to be in the right place. ANy help would be greatly appreciated.
  2. Dec 21, 2013 at 3:10 AM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    You could have flushed a bunch of junk down into the IAC Idle Air Control.
    Thats located under the Throttle Body.
    It could be also that you now have a clean throttle body bore and your car has to relearn and adjust to the increased amount of air entering it.
    Maybe disconnect the battery for a while to reboot the system so it can reset itself?.
    You could also check and see if your butterfly in the Throttle body is moving freely.
  3. Dec 21, 2013 at 8:39 AM
    YoTaVIdA
    YoTaVIdA [OP] NWEST
    Portland, OR
    thanks for the reply! I tried my best to keep stuff out of my IAC, but im sure some got in. Would i be able to take it off and flush it out since it has a couple of lines running out of it? before i put the intake back i checked the butterfly and it was moving when i turned the throttle cables. Ill see if pulling the battery works. Thanks for the help
  4. Dec 21, 2013 at 10:22 AM
    YoTaVIdA
    YoTaVIdA [OP] NWEST
    Portland, OR
    FIXED IT!! I pulled the neg battery cable and ECU and left it for about 10 min made some coffee then put it all back on. When i turned the engine on it idled extremely low for a cold engine, but every 30 sec it moved up in RPMS until it reached 2000. After about 10 minutes the idle slowly dropped to about 700-900. IT PURRSss like a kitten and has such great response when i drive it. It feels like a new truck. Thanks for the suggestions SIN
