Idle issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by jesse20053, Jul 29, 2015.
  1. Jul 29, 2015 at 1:15 PM
    jesse20053
    jesse20053 [OP] Member
    1995 toyota tacoma
    2 inch lift and too many new parts to list
    i have a 1995 tacoma 4x4 3.4 the idle when you first start is around 2200 rpm and when it warms up it drops down to about 1400- 1600.. ive replaced the iacv and and all new vacum hoses and cleaned the throttle body still no change.... Any ideas?
  2. Jul 29, 2015 at 1:54 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    loose or cracked vacuum lines.
    the idle speed adjustments are a "fixed" setting "tamper" marked with yellow paint, so unless you have reason to believe someone tampered with them, its going to be a vacuum leak causing high idle
  3. Jul 31, 2015 at 8:28 AM
    jesse20053
    1995 toyota tacoma
    It's not the vacuum lines I replaced all of them new and have even rechecked them to make sure they are right
  4. Jul 31, 2015 at 4:24 PM
    jesse20053
    1995 toyota tacoma
    It's a manual transmission and the iacv is new... Everyone I talk to says it's the computer I just find that hard to believe.. I've looked for a new throttle body thinking it's that but can't find one anywhere... I don't want to spend 400 on a computer and that not fix it.. the iacv made the idle start to jump when coming to a stop when I put the new one on...
  5. Aug 7, 2015 at 5:37 PM
    jesse20053
    1995 toyota tacoma
    It's fixed now I had to cap off a vacuum hose that runs to the ac that new engine I installed didn't have Thrace valve and never noticed it...
  6. Aug 7, 2015 at 5:41 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    What hose? I had this problem for a year and just fixed it ...combo between iac and tb...installing a new engine right now too
  7. Aug 10, 2015 at 8:36 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Did you try resetting ECU? Pull ECU fuse or disconnect battery for a bit. Let it idle after reinstalling for 15-20 minutes and see if that helps.
  8. Aug 11, 2015 at 7:17 AM
    keakar
    karl
    louisiana
    he said its fixed
    it was a vacuum leak
